On 11/14, Mark Rivers via Tech-talk wrote:
> So on Linux running the "curl" command via a call to system() is actually almost 3 times faster than calling either of the libraries directly. This surprises me.
That makes no sense. There must be something different about how you're
using libcurl vs. curl. Have you tried curl's "--libcurl <file>"
option? I would try that. Basically, take the curl command line that
works, and then add the "--libcurl <file>" option to it, and it will
emit C source code for a program using libcurl that does the same thing.
Compare that with how you're using libcurl.
Lewis
- Re: Uploading a file with SFTP from an EPICS driver Michael Davidsaver via Tech-talk
- RE: Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
- Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
RE: Uploading a file with SFTP from an EPICS driver Freddie Akeroyd - UKRI STFC via Tech-talk
<2019>
2025
<2019>
2025
