1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Custom asyn input EOS
From: "Hudson, Lee \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
Date: Tue, 10 Dec 2019 08:55:22 +0000
I have a motion controller I’m writing a driver for and it communicates by sending XML with no line terminators. This is proving to be a pain as any asyn reads time out. Luckily I know exactly what XML structure I expect back as the controller only uses this mechanism to respond to requests and it will always respond using the same structure the request was sent in. I would like to be able to set the input eos to the last element in the XML structure, eg, </sequencer_prog>. I tried to use the method asynOctetSyncIO->setInputEos() as this has an EOS string and length as parameters but looking at the implementation in asynInterposeEos.c I can see that the length of the EOS given is used in a switch statement and anything greater than 2 is invalid. Is there any way to specify a custom EOS of any length?
Thanks
Lee
Prev: Re: Linker error with vendor library Mark Rivers via Tech-talk
Next: pco Camera USB and IEEE interface Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: Custom asyn input EOS Mark Rivers via Tech-talk
ANJ, 10 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
