1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: ADSpinnaker timestamp
To: Tamas Kerenyi <[email protected]>
Date: Tue, 10 Dec 2019 19:30:14 +0000
I think I understand why the ChunkTimestamp is jumping between positive and negative. GenICam integers are 64 bits. ADGenICam truncates them to 32 bits.
EPICS base, asyn, and ADCore have all recently added support for 64 bit integers. I could thus change ADGenICam to use int64in and int64out records for GenICam integers. This would however require EPICS base 3.16.1 or later.
Sent from my iPhone
On Dec 10, 2019, at 10:32 AM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Hi Tamas,
What camera are you using?
In ADSpinnaker there is a PV to tell the driver to use the embedded time stamp from the camera for the timeStamp property of the NDArray.  If you select this you may not need the ChunkTimestamp.
The timeStamp is saved in the TIFF, HDF5, and netCDF file writing plugins.
Sent from my iPhone
On Dec 10, 2019, at 8:28 AM, Tamas Kerenyi via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
Hi!
I’m using ADSpinnaker. How should I interpret the „ChunkTimestamp”? I’d like to know the timestamp of the pictures in nanoseconds.
labs-utg-test:cam1:GC_ChunkTimestamp_RBV 2019-12-10 16:01:34.642297 1557832136
labs-utg-test:cam1:GC_ChunkTimestamp_RBV 2019-12-10 16:01:36.640736 -737150176
labs-utg-test:cam1:GC_ChunkTimestamp_RBV 2019-12-10 16:01:38.641100 1262848184
labs-utg-test:cam1:GC_ChunkTimestamp_RBV 2019-12-10 16:01:40.643660 -1032134232
Best Regards,
Tamas Kerenyi
ICS Division, HW and Integration Group
Re: ADSpinnaker timestamp Mark Rivers via Tech-talk
ADSpinnaker timestamp Tamas Kerenyi via Tech-talk
Prev: Re: pco Camera USB and IEEE interface Mark Rivers via Tech-talk
Next: Re: ADSpinnaker timestamp Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Prev: Re: ADSpinnaker timestamp Mark Rivers via Tech-talk
ANJ, 10 Dec 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
