1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Periodic scan rate less than 20 msec
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 18 Dec 2019 09:24:08 +0100
Hi Gianfranco,
So - referring to Michael's question - what's your use case? Is it an input or an output? What kind of device are you connecting to? What type and amount of data is involved? What is the requirement that drives your attempt to process records "as fast as possible"?
We would like to know more about your application, because what you're trying to do sounds like there could be more efficient ways to handle it.
Cheers,
~Ralph
Periodic scan rate less than 20 msec dmnr infn via Tech-talk
Re: Periodic scan rate less than 20 msec Michael Davidsaver via Tech-talk
Re: Periodic scan rate less than 20 msec dmnr infn via Tech-talk
Prev: computer for EPICS with EIGER 4M John Dobbins via Tech-talk
Next: Job posting at ESS (European Spallation Source ERIC, Lund, Sweden) Karl Vestin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Periodic scan rate less than 20 msec dmnr infn via Tech-talk
Next: Job posting at BESSY II (Helmholtz-Zentrum Berlin) Andreas Balzer via Tech-talk
ANJ, 18 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
