1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: Ethernet question
From: "J. Lewis Muir via Tech-talk" <[email protected]>
Date: Mon, 6 Jan 2020 14:39:21 -0600
On 12/23, Mark Rivers via Tech-talk wrote:
> On further investigation I found that the problem only occurs when using 10 Gbit Ethernet adapters.  When using a 1 Gbit adapter it works fine.  I was able to see this in a single machine that has both 10 Gbit and 1 Gbit adapters.  If I use the 1 Gbit adapter it works fine, if I use the 10 Gbit adapter it fails (but kind of works as described above).  On 3 separate systems 1 Gbit works, and 3 other systems 10 Gbit fails.
Is the NIC driver the same for the 1 GbE and the 10 GbE NICs on Linux?
Do you have a Windows machine with a 10 GbE NIC that you could try?
Do you have a Mac with a 10 GbE NIC that you could try?
Lewis
RE: Ethernet question Mark Rivers via Tech-talk
Prev: Re: New sequencer release 2.2.8 J. Lewis Muir via Tech-talk
Next: Re: Ethernet question J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Prev: Re: Ethernet question Hinko Kocevar via Tech-talk
Next: RE: Ethernet question Mark Rivers via Tech-talk
ANJ, 09 Jan 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
