1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: Finding the PV for a specific device?
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 7 Jan 2020 19:54:55 +0000
Emma,
Which model of Ensemble controller are you using?
You'll need to enable ASCII communication using the Ensemble
Configuration Manager before the controller can talk to EPICS.  This is
documented in a place where no one is likely to find it:
https://github.com/epics-motor/motorAerotech/blob/9abae6420d0e7df2a7369105f577cc5f783e3a6b/aerotechApp/src/README#L73
Kevin
On 1/6/20 11:18 AM, Emma-Elizabeth Cating-Subramanian via Tech-talk wrote:
> Hello,
> I'm just starting to use EPICS and am running into a bit of an issue.
> I've got an Aerotech Ensemble stage connected to my computer via
> ethernet. I want to be able to interface with it through EPICS. How do I
> find out what the PV is that I need to give to EPICS? Does EPICS just
> search for ethernet devices and assign PVs? If so, how do I retrieve
> that information?
> I've asked this question of a few people now and no one has been able to
> give me a useful answer, so perhaps I have been phrasing it incorrectly.
> Maybe a better way is, if you connected a new Aerotech stage to your
> computer, could you walk me through the steps you would take to make it
> move using EPICS?
> Thanks,
> Emma Cating-Subramanian
> Postdoctoral Researcher
> Kapteyn-Murnane group
> JILA
> CU Boulder
Finding the PV for a specific device? Emma-Elizabeth Cating-Subramanian via Tech-talk
Prev: Re: Ethernet question Rod Nussbaumer via Tech-talk
Next: RE: Ethernet question Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: Finding the PV for a specific device? Mooney, Tim M. via Tech-talk
Next: Re: New sequencer release 2.2.8 J. Lewis Muir via Tech-talk
ANJ, 07 Jan 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
