On 1/9/20 4:01 PM, J. Lewis Muir via Tech-talk wrote:
Whenever I upgrade, I spend a fair amount of time downloading all the
distribution files, patching, and getting everything to build correctly.
I wish to have binary packages that I could build once and then install
on Linux and macOS machines. I was thinking of using pkgsrc so that
I could use one package management system to build and install binary
packages for a number of platforms including Linux and macOS. Then, for
example, it would be as simple as "pkgin install epics" to install EPICS
on a machine.
I suggest you take a look at
Sumo from HZB (BESSY-2), it's the closest equivalent to automated package management for EPICS that I've come across, but it installs everything from source. Once it has a database of your support modules, you just have to give each IOC a configure/MODULES
file, which tells Sumo what support modules and versions the IOC needs. Then it can download, patch if necessary, configure and build them all from source, and configure the IOC's configure/RELEASE file, all in a single command. If any subset of those modules
have already been built with the same set of upstream dependencies it will reuse those and only build the extra modules that are needed.
The APS-U Accelerator Control system IOCs will be built using Sumo, so far it Just Works™.
- Andrew
Complexity comes for free, Simplicity you have to work for.
- EPICS release series after 7.0: 7.1 or 8.0? J. Lewis Muir via Tech-talk
- Re: EPICS release series after 7.0: 7.1 or 8.0? Johnson, Andrew N. via Tech-talk
- Re: EPICS release series after 7.0: 7.1 or 8.0? Wang Xiaoqiang via Tech-talk
- Re: EPICS release series after 7.0: 7.1 or 8.0? (ABI) Michael Davidsaver via Tech-talk
- Re: EPICS release series after 7.0: 7.1 or 8.0? (ABI) J. Lewis Muir via Tech-talk
- RE: EPICS release series after 7.0: 7.1 or 8.0? (ABI) Mark Rivers via Tech-talk
Re: EPICS release series after 7.0: 7.1 or 8.0? (ABI) Maren Purves via Tech-talk
<2020>
2025
<2020>
2025
ANJ, 09 Jan 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
