Subject: Error when running st.cmd of SmartMotor
To: <[email protected]>
Date: Fri, 10 Jan 2020 18:31:41 +0900
hi
I'm currently developing an IOC that runs a motor and I'm having trouble.
When I run "st.cmd" it produces this output:
odroid@odroid:~/App/epics/iocs/testMotor/iocBoot/ioctestMotor$ ./st.cmd
#!../../bin/linux-arm/testMotor
## You may have to change testMotor to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("IOC","ioctestMotor")
epicsEnvSet("TOP","/home/odroid/App/epics/iocs/testMotor")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
epicsEnvSet("ASYN","/usr/local/epics/modules/asyn4-37")
epicsEnvSet("STREAM","/home/odroid/App/epics/modules/stream")
epicsEnvSet("MOTOR","/usr/local/epics/modules/motor-R6-10-1")
< epicsEnvSet(STREAM_PROTOCOL_PATH, "odroid/App/epics/iocs/testMotor/testMotorApp/Db")
st.cmd line 7: Can't open "epicsEnvSet": No such file or directory.
cd "/home/odroid/App/epics/iocs/testMotor"
dbLoadDatabase "dbd/testMotor.dbd"
testMotor_registerRecordDeviceDriver pdbbase
drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyS2",0,0,0)
asynSetOption("SERIALPORT",-1,"baud","19200")
asynSetOption("SERIALPORT",-1,"bits","8")
asynSetOption("SERIALPORT",-1,"parity","none")
asynSetOption("SERIALPORT",-1,"stop","1")
asynSetOption("SERIALPORT",-1,"clocal","Y")
asynSetOption("SERIALPORT",-1,"crtscts","N")
asynOctetSetInputEos("SERIALPORT",0,"\r")
asynOctetSetOutputEos("SERIALPORT",0,"\r")
KKTechSetup(1,8,10)
KKTechConfig(0,"SERIALPORT")
## Load record instances
#dbLoadRecords("db/xxx.db","user=odroid")
dbLoadRecords("db/testMotor.db","PORT='SERIALPORT'")
#dbLoadRecords("db/testMotor.db")
cd "/home/odroid/App/epics/iocs/testMotor/iocBoot/ioctestMotor"
iocInit
Starting iocInit
## EPICS R3.15.6
## EPICS Base built Dec 23 2019
drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults to "."                                                      <-------?????
devMotorAsyn::init_record IOC:m1 bad link invalid INST_IO Must be asyn(<port> <addr> <timeout>)userParams             <-------?????
2020/01/09 17:46:06.002 devMotorAsyn::build_trans: IOC:m1 error calling queueRequest, asynManager::queueRequest asynUser not associated with a port  <-------?????
## Start any sequence programs
#seq sncxxx,"user=odroid"
epics>
Below is the contents of the st.cmd file.
< envPaths
cd "${TOP}"
KKTechSetup(1,8,10)
cd "${TOP}/iocBoot/${IOC}"
iocInit
Below is the contents of the testMotor.db file.
grecord(motor,"IOC:m1")
field(DESC,"$(DESC="motor $(M)")")
field(DTYP,"KKTech")
field(DIR,"$(DIR=Pos)")
field(VELO,"$(VELO=1)")
field(VBAS,"$(VBAS=.1)")
field(ACCL,"$(ACCL=.2)")
field(BDST,"$(BDST=0)")
field(BVEL,"$(BVEL=1)")
field(BACC,"$(BACC=.2)")
field(OUT,"#C$(C=0) S$(S) @")
field(MRES,"$(MRES=0.01)")
field(PREC,"$(PREC=5)")
field(EGU,"$(EGU=mm)")
field(DHLM,"$(DHLM=100)")
field(DLLM,"$(DLLM=-100)")
field(INIT,"$(INIT="")")
field(TWV,"1")
I can't solve the above 4 errors.
   I would appreciate a very small tip.
Thank you.
Error when running st.cmd of SmartMotor <<-- cancel the question 최원철 via Tech-talk
Prev: Re: EPICS release series after 7.0: 7.1 or 8.0? Wang Xiaoqiang via Tech-talk
Next: Error when running st.cmd of SmartMotor <<-- cancel the question 최원철 via Tech-talk
Prev: Re: EPICS Smartmotor example IOC 최원철 via Tech-talk
