Subject: Re: Question about two minor issues with IOCs
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
Date: Thu, 16 Jan 2020 18:02:43 +0000
Hi Mark,
I am currently running the following versions of all modules:
ADCore - R3-8
base - R7.0.3.1
asyn - R4-37
I have also seen this buffer full error with ADCore R3-7 IOCs, though I don't remember seeing it on any earlier versions, and I don't remember
which base/asyn those were running.
In my case, I see at least a few printings of that error on every IOC boot, though this may be because I have several additional plugins loading
PVs at startup, which means that I have more PVs than the example IOCs, however, I had the same amount of plugins loading without this error on earlier
releases.
The other error also happens every IOC boot, but that one I haven't seen until recently, although it is possible it simply went unnoticed by me
in earlier versions.
Jakub
Sent: Thursday, January 16, 2020 12:40 PM
To: Wlodek, Jakub <[email protected]>
Cc: [email protected] <[email protected]>
Subject: RE: Question about two minor issues with IOCs
Hi Jakub,
I have been seeing both of those messages on my areaDetector IOCs as well.
Ø  Error (511,511) PV: 13SIM1::TIMEZONE devStringinEnvVar (init_record) Illegal INP parm field
That message happens every time the IOC boots for me.  I have been assuming is a problem with devIocStats, and have been meaning to track it down.
Ø  callbackRequest: cbLow ring buffer full
That message only very occasionally happens for me at the end of iocInit.  I believe it happens when the number and rate of driver callbacks for PVs are too large, so that the queue in EPICS base overflows.  We could probably eliminate them by increasing the size of that queue.  But before doing that I want to know why they just started happening, and I did not see them before.
I am running base 7.0.3.1 and the master branch of asyn.  The question is whether it was a change in either of those that caused the messages to start happening.
Note that this error can actually be serious, because it means that some records will not have their correct values, because the callback events were missed.
Do you see those cbLow messages every time you boot?  What version of base,  asyn and ADCore are you using?
From: Tech-talk <[email protected]> On Behalf Of Wlodek, Jakub via Tech-talk
Sent: Thursday, January 16, 2020 9:53 AM
To: [email protected]
Subject: Question about two minor issues with IOCs
Hi all,
I have been working on setting up some new USB cameras at a beamline recently, and I noticed two errors showing up in the IOC
shell, though the IOCs for the cameras actually work fine after startup. I wanted to ask if anyone knows why these show up, and how
to resolve them. To make sure it wasn't specific to the driver I had written, I compiled ADSimDetector against the same base, asyn etc,
and I still saw them showing up:
The first seems to be an issue with autosave, as this shows up right after reboot_restore starts:
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
The second issue happens after the auto_settings.req file is loaded:
create_monitor_set("auto_settings.req", 30, "P=13SIM1:")
And is buffer full message is repeated ~30 times.
After all of these messages, I get a message that all the PVs are connected, and the IOC runs with no issues, which is puzzling to me.
If anyone could give me some advice on the source and solution to these that would be great.
Jakub Wlodek
RE: Question about two minor issues with IOCs Mark Rivers via Tech-talk
Question about two minor issues with IOCs Wlodek, Jakub via Tech-talk
Prev: RE: Question about two minor issues with IOCs Mark Rivers via Tech-talk
Next: RE: Question about two minor issues with IOCs Mark Rivers via Tech-talk
