Subject: RE: Probelm with ethernet interface of Galil controller [DLM=For-Official-Use-Only]
From: "CLIFT, Mark via Tech-talk" <[email protected]>
Date: Sat, 18 Jan 2020 08:46:23 +0000
The problem reported in this case is interesting, since it appears very repeatable.  In that opening the full MEDM screen causes the problem.
To Galil users that have such a repeatable network issue.  In my experience Galil will fix the firmware if the customer provides a network "log" they can "play back" at their office to produce the error upon request.  To capture this log use this command.
set PATH=C:\Program Files\Wireshark;%PATH%
dumpcap -i "LabNetwork" -b filesize:10000 -b files:100 -w capture.pcapng
          The command is referenced at the link below:
           https://www.wireshark.org/docs/man-pages/dumpcap.html
          The -i switch is the name of your interface. The first -b sets up the circular buffer capturing files up to a certain            file size. The second one tell the buffer to rotate through n files. The -w is the base file name.
          Once you see the error, close the capture with CTRL+C.
Send the logs to Galil.  Recommend you try Troy Miller [email protected] who is their firmware expert.  If you have trouble finding the correct contact, let me know.  As a routine customer, I've worked with Galil for a while, and know some of the folks there.
Kind regards,
Prev: RE: PicoScope support? Loeher, Bastian Dr. via Tech-talk
Next: RE: Probelm with ethernet interface of Galil controller [DLM=For-Official-Use-Only] CLIFT, Mark via Tech-talk
Prev: Re: Open positions at ITER Ralph Lange via Tech-talk
