1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: EPICS_CA_MCAST_TTL equivalent for pvAccess
From: Denise Finstrom via Tech-talk <[email protected]>
To: [email protected]
Cc: Jim Smedinghoff <[email protected]>
Date: Wed, 22 Jan 2020 10:18:06 -0600 (CST)
Hello,
Is there an equivalent to EPICS_CA_MCAST_TTL for the pvAccess protocol?
We are attempting to use multicast for PV search and haven't found a way to change TTL values when using pvAccess. When we set EPICS_PVA_ADDR_LIST to a multicast address, the multicast goes out with a TTL of one and doesn't get routed to other subnets. We are successfully using multicast for PV search with the CA protocol and EPICS_CA_MCAST_TTL. We are looking to do the same with pvAccess, but the EPICS_PVA_MCAST_TTL environment variable doesn't seem to exist. We are using base-7.0.3.1. Any advice would be appreciated.
Denise
Re: EPICS_CA_MCAST_TTL equivalent for pvAccess Michael Davidsaver via Tech-talk
Prev: Oxford IC101 support? Mark Rivers via Tech-talk
Next: EPICS support for PoE Injector Hub Gessner, Spencer J. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Next: Re: EPICS_CA_MCAST_TTL equivalent for pvAccess Michael Davidsaver via Tech-talk
ANJ, 22 Jan 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
