1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: possibility of using areaDetector to drive Varax 4343 detector
From: "ChenZhang@Gmail via Tech-talk" <[email protected]>
Date: Fri, 24 Jan 2020 13:54:41 -0600
The vendor software is called XIS (Windows), which allows us to write frames to a buffer, then manually save them to disk.  We will contact the vendor to confirm if a different SDK is used for this new model.
Chen
> On Jan 24, 2020, at 1:41 PM, Mark Rivers <[email protected]> wrote:
>> I was wondering if it would be possible to use areaDetector to drive Varax 4343.
> Do you know what software is provided with that detector?  There are 2 areaDetector drivers for Varax flat panel detectors, ADPerkinElmer and ADDexela.  Does the 4343 use the same SDK as either of these?
> Mark
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of ChenZhang@Gmail via Tech-talk
> Sent: Friday, January 24, 2020 1:26 PM
> To: [email protected]
> Subject: possibility of using areaDetector to drive Varax 4343 detector
> Hi All,
> We are trying to test the hardware triggering of Varax 4343 for HT-HEDM, and the vendor software does not support directly dumping frames from buffer to disk.  I was wondering if it would be possible to use areaDetector to drive Varax 4343.
> Best,
> Chen
> Chen Zhang
> Postdoc Researcher
> Department of Mechanical Engineering
> Colorado School of Mines
> 1500 Illinois Street Golden, CO 80401
> [email protected]
> [email protected]
Re: possibility of using areaDetector to drive Varax 4343 detector Miceli, Antonino via Tech-talk
possibility of using areaDetector to drive Varax 4343 detector ChenZhang@Gmail via Tech-talk
RE: possibility of using areaDetector to drive Varax 4343 detector Mark Rivers via Tech-talk
Prev: RE: Getting images from area detector plugins Mark Rivers via Tech-talk
Next: Re: possibility of using areaDetector to drive Varax 4343 detector Miceli, Antonino via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Prev: RE: possibility of using areaDetector to drive Varax 4343 detector Mark Rivers via Tech-talk
ANJ, 24 Jan 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
