1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: ezca for 3.15
From: "Siddons, David via Tech-talk" <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Sat, 1 Feb 2020 21:53:07 +0000
Hi Mark,
   OK, I rebuilt my extensions directory, and built ezca. All went well. When I try to use ezca I hit problems. Here is my simple program; it reads a vector, changes one element and then writes it back:
#include <ezca.h>
main()
int d;
int s[384];
   ezcaGet("det1.TSEN", ezcaLong, 384, &s);
   ezcaGet("det1.CHAN",ezcaLong,1,&d);
   s[d]=1;
  ezcaPut("det1.TSEN", ezcaLong, 1, s);
and my compile line:
gcc -o testenable -L/home/peter/epics/extensions-master/lib -I/home/peter/epics/extensions-master/include -I//home/peter/epics/base-3.15.6/include/ -lezca testenable.c
which gets me:
In file included from testenable.c:1:0:
/home/peter/epics/extensions-master/include/ezca.h:77:61: error: unknown type name ‘chid’; did you mean ‘void’?
 epicsShareFunc int epicsShareAPI ezcaPvToChid(char *pvname, chid **cid);
                                                             void
/home/peter/epics/extensions-master/include/ezca.h:103:2: error: unknown type name ‘TS_STAMP’
  TS_STAMP *timestamp, short *status, short *severity);
/home/peter/epics/extensions-master/include/ezca.h:107:45: error: unknown type name ‘TS_STAMP’
  char ezcatype, int nelem, void *data_buff, TS_STAMP *timestamp,
testenable.c:2:1: warning: return type defaults to ‘int’ [-Wimplicit-int]
 main()
So what am I doing wrong?
Pete.
Sent: Saturday, February 1, 2020 3:56 PM
To: Siddons, David <siddons at bnl.gov>
Hi Pete,
I suspect you may be using an old version of ezca?  The latest version is here:
https://github.com/epics-extensions/extensions
<https://github.com:epics-extensions/extensions>
I just built successfully with that version on base 7.0.3.1, so I am pretty sure 3.15 will build fine as well.
Here is the output when building:
corvette:extensions_new/src/ezca>make
perl -CSD /corvette/usr/local/epics/base-7.0.3.1/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[1]: Entering directory `/usr/local/epics/extensions_new/src/ezca/O.linux-x86_64'
perl -CSD /corvette/usr/local/epics/base-7.0.3.1/bin/linux-x86_64/mkmf.pl  -m ezca.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-7.0.3.1/include/compiler/gcc -I/corvette/usr/local/epics/base-7.0.3.1/include/os/Linux -I/corvette/usr/local/epics/base-7.0.3.1/include   -I../../../include           ezca.o ../ezca.c
make[1]: Leaving directory `/usr/local/epics/extensions_new/src/ezca/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/corvette/usr/local/epics/base-7.0.3.1/include/compiler/gcc -I/corvette/usr/local/epics/base-7.0.3.1/include/os/Linux -I/corvette/usr/local/epics/base-7.0.3.1/include   -I../../../include           -c ../ezca.c
../ezca.c: In function 'pop_channel':
../ezca.c:7731:18: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat=]
    sizeof(struct channel)*NODESPERMAL, Channel_avail_hdr);
../ezca.c:7731:18: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
../ezca.c: In function 'pop_monitor':
../ezca.c:7812:21: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat=]
       sizeof(struct monitor)*NODESPERMAL, Monitor_avail_hdr);
../ezca.c:7812:21: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
../ezca.c: In function 'pop_work':
../ezca.c:7893:21: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat=]
       sizeof(struct work)*NODESPERMAL, Work_avail_hdr);
../ezca.c:7893:21: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
/usr/bin/ar -rc    libezca.a    ezca.o
/usr/bin/ranlib libezca.a
/usr/bin/g++ -o libezca.so -shared -fPIC -Wl,-hlibezca.so -L/usr/local/epics/extensions_new/lib/linux-x86_64 -L/usr/local/epics/base-7.0.3.1/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/extensions_new/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/base-7.0.3.1/lib/linux-x86_64           -rdynamic -m64         ezca.o    -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libezca.so
Installing library ../../../lib/linux-x86_64/libezca.a
Cheers,
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Siddons, David via Tech-talk <tech-talk at aps.anl.gov>
Sent: Saturday, February 1, 2020 2:33 PM
To: EPICS Tech Talk
Subject: ezca for 3.15
I want to use ezca with 3.15, but it seems to be a mess of missing header files, presumably things dropped with 3.15 (e.g. tsDefs.h, cadef.h). Has anyone made it work?
Pete.
Re: ezca for 3.15 Mark Rivers via Tech-talk
ezca for 3.15 Siddons, David via Tech-talk
Prev: Re: Problems with scaler record and base 7.0.3.1 Mark Rivers via Tech-talk
Next: Re: ezca for 3.15 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: ezca for 3.15 Mark Rivers via Tech-talk
ANJ, 01 Feb 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
