Subject: Re: asynMotorAxis
Cc: "Koennecke Mark \(PSI\)" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 7 Feb 2020 11:41:59 +0000
Search for motorRecResolution. That is what the parameter is called.
Sent from my iPhone
> On Feb 7, 2020, at 11:05 AM, Mark Rivers via Tech-talk <[email protected]> wrote:
> I know the resolution is available to the Newport XPS driver, because it uses it for profile moves.
> I forget how I did that, and don’t have good search tools available from my phone. I seem to recall functions at some layer that send that motor record information to the drivers. Search for motorResolution in MotorSrc and NewportSrc.
> Mark
> Sent from my iPhone
>> On Feb 7, 2020, at 10:33 AM, Koennecke Mark (PSI) via Tech-talk <[email protected]> wrote:
>> Hi,
>> I am writing a motor driver for an old piece of french equipment called EuroMove.
>> This is going well. But the thing does not implement homing in the controller. I try
>> to implement this in the asynAxis driver. To that purpose, I need the motor resolution.
>> It is in principle there, in the MRES field of the motor record.  I tried:
>> pC_->getDoubleParm(axisNo_, pC_->motorResolution_, &resolution);
>> but this gave me a 0 instead of the .01 to which the MRES field had been configured in the
>> motor substitutions file. I know the record sees this because the conversion for physical
>> units to motor steps is working.
>> I also tried motorEncoderRatio_ which returned infinity.
>> My question now is how I can get at that information in an asynMotorAxis driver?
>> Or is my only option to write a configuration command or axis creation command which
>> passes the resolution value in?
>> This is against base3.14.12 and motor6.9 on RHEL7 linux.
>> Best Regards,
>>    Mark Koennecke
asynMotorAxis Koennecke Mark (PSI) via Tech-talk
Re: asynMotorAxis Mark Rivers via Tech-talk
Prev: Re: asynMotorAxis Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Next: asynMotorAxis Koennecke Mark (PSI) via Tech-talk
