Subject: Re: SNCSEQ Error Windows
To: "Hetz, Benjamin" <[email protected]>
Date: Tue, 11 Feb 2020 11:59:38 +0000
Can you send the Makefile you are using, and a listing of the files in the source directory?
From: Tech-talk <[email protected]> on behalf of Hetz, Benjamin via Tech-talk <[email protected]>
Sent: Tuesday, February 11, 2020 3:06 AM
To: [email protected]
Subject: SNCSEQ Error Windows
Hello,
I am having following problem:
I am using the Windows build of EPICS with VS compiler and Strawbery Perl. Compiling SNCSeq 2.2.8 went fine and also its demo/example files were build in seq-2_2_8\examples and running.
Following the instruction from https://www-csr.bessy.de/control/SoftDist/sequencer/Compiling.html I created an example IOC and changed SNCSEQ in configure/REALESE to "C:/opt/epics/base-7_0_3/modules/seq-2_2_8".
Running now gmake in the example ioc top dir yields following error:
gmake[3]: *** No rule to make target 'sncExample.obj', needed by 'interlocksSupport.lib'.  Stop.
gmake[3]: Leaving directory 'C:/opt/epics/interlocks/interlocksApp/src/O.windows-x64-static'
gmake[2]: *** [C:/opt/epics/base-7_0_3/configure/RULES_ARCHS:58: install.windows-x64-static] Error 2
gmake[2]: Leaving directory 'C:/opt/epics/interlocks/interlocksApp/src'
gmake[1]: *** [C:/opt/epics/base-7_0_3/configure/RULES_DIRS:84: src.install] Error 2
gmake[1]: Leaving directory 'C:/opt/epics/interlocks/interlocksApp'
gmake: *** [C:/opt/epics/base-7_0_3/configure/RULES_DIRS:84: interlocksApp.install] Error 2
May anyone please help?
Thank you, Ben
RE: SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
Prev: SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
Next: RE: SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
