Subject: Re: Building EPICS base/IOC only for cross target
From: Florian Feldbauer via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 11 Feb 2020 17:52:33 +0100
Hey Michael,
as far as I understood, they would like to build everything (base, support modules and IOC) just for the target arch.
But the error occurs for the IOC (which contains a custom support module)
The missing library is the libisegHal which is only build for linux-arm as a part of the same yocto image.
The library is needed for iseg's support module.
Cheers,
Florian
Am 11.02.2020 um 16:34 schrieb Michael Davidsaver:
Can you clarify a couple of points?
Are you referring to building EPICS Base itself, or a support module / IOC application?
Which libraries are missing?  (this might answer the previous question)
On 2/11/20 5:27 AM, Florian Feldbauer via Tech-talk wrote:
Hey all,
I was contacted by iseg with the following problem:
They want to include EPICS in their yocto image for the crate controllers.
The host system is a linux-x86_64 system, the target arch linux-arm.
Currently their Yocto recipe fails, because EPICS is build for both host and target arch and some libraries are missing for the host.
Is there a way to build EPICS only for a target architecture?
Best regards,
Florian
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: Building EPICS base/IOC only for cross target Johnson, Andrew N. via Tech-talk
Building EPICS base/IOC only for cross target Florian Feldbauer via Tech-talk
Re: Building EPICS base/IOC only for cross target Michael Davidsaver via Tech-talk
Prev: Re: Phoebus image data dimensions Kasemir, Kay via Tech-talk
Next: Re: Building EPICS base/IOC only for cross target Johnson, Andrew N. via Tech-talk
Prev: Re: Building EPICS base/IOC only for cross target Michael Davidsaver via Tech-talk
