On 2/11/2020 1:46 PM, Matt Rippa wrote:
I know we (like you) have used NFSv2 RTEMS client with an CentOS 7 server. The issue you cite seems to be related to documentation so I don't see a particular concern with that.
Based on this, it appears to still be there. https://linuxize.com/post/how-to-install-and-configure-an-nfs-server-on-centos-8/ I couldn't quickly find anything about NFSv2 on a recent version of Fedora which would be a hint of even longer term point of view.
I can't help with the funding but I can say that the RTEMS Project would love to see this as well. One requirement to consider is whether to support both the legacy and libbsd TCP/IP stacks. One option for a libbsd only solution is to focus on adding the FreeBSD NFS client to libbsd. That would provide a solid base for the future and it would get updated with the rest of the libbsd code base. But it would leave BSPs which don't have drivers in the new stack out in the cold. The path for them might be focused on improvements to the existing NFS client (if v2->v3/4 is possible that way). AFAIK this is the TCP/IP stack supported by many of the BSPs the EPICS community uses. Providing solutions for both stacks is likely necessary because some of the older boards may not have the RAM to support libbsd and there is always the issue of making sure there are drivers. Solving this the best way for both TCP/IP stacks upgrades the capability for all boards in use without touching any BSP or device driver specifics. I am happy to chat about this in more detail or investigate the amount of work required. In case you all never hear it, the RTEMS developers are proud RTEMS is used by the EPICS community. You all do great work and contribute to increasing humanity's understanding of the universe. And as a final aside, we would really like to get EPICS integrated into the RTEMS testing cycle so we all can be confident that EPICS and RTEMS work together properly with no unexpected breakages. Thanks. --joel sherrill RTEMS/OAR
ANJ, 11 Feb 2020 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
