Subject: Re: Standard RTEMS NFSv3 client
To: Heinz Junkes <[email protected]>
Cc: Talk EPICS Tech <[email protected]>
Date: Wed, 12 Feb 2020 10:49:10 -1000
Hi Heinz and everyone,
Thanks for the replies and sharing your experiences.
We're also using the shared PowerPC (MVMExxxx), beatnik and MVME3100 bsp's. I believe these are all on the old network stack.
Is there a way to stay on RTEMS 4.10.x and implement these two major steps:
1) Upgrade to the new libbsd stack (does it require RTEMS 5?).
2) Upgrade to NFS v3 support.
I don't know if there's any demand for NFSv3 on the old stack? Our PPC MVMExxxx boards have RAM ranging from 64MB to 256MB and more. Is anyone using the 68k vme boards where having enough RAM could be an issue?
Cheers,
-Matt
On Tue, Feb 11, 2020 at 10:55 PM Heinz Junkes <[email protected]> wrote:
Hi, Matt,
I have been using the libbsd TCP/IP stack in RTEMS5/EPICS7 since the end of last year.
I have already had some success with it, such as a "standard" /etc/rc.conf (dhclient.conf, …)file(s)
and e.g. initialization of Ethernet interfaces via DHCP. This looks quite good so far, but still has
many problems when using EPICS.
(E.g. I have not yet managed to ask the DHCP-server for dhcp-option-129 etc.)
But I think it is the right way for the future.
There are still missing things like
NTP (I am trying to integrate ptp2 now)
NFSv3 (here I still have to use the stuff from Till)
there are also problems with the support of PCI/VME ... (at least for my MVMExxxx boards)
I think it's the right way to go for this kind of stuff on FreeBSD and I would like to participate
in funding in this direction.
Viele Grüße Heinz
Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
Faradayweg 4-6        |
D - 14195 Berlin        | E-Mail:        [email protected]
> On 11. Feb 2020, at 20:46, Matt Rippa <[email protected]> wrote:
> Hello EPICS/RTEMS users,
> Back in 2017 there were some emails in the EPICS and RTEMS community about requesting support for an RTEMS NFSv3 client . We're getting increasing requests from our IT department to support this but don't see an easy way forward. We're running RTEMS 4.10.2 and NFSv2 is currently working and supported by default with a CentOS 6 file server. Moving to CentOS 7 we're getting push back supporting NFSv2. It's not enabled by default and we have to configure it. Our IT department believes the ability to enable NFS v2 on CentOS7 is a bug and it may not function properly after routine maintenance on a CentOS7 machine. This may be related to [1] below. A few questions:
> 1. Is there any risk manually configuring a CentOS7 nfs server to use version 2 via /etc/sysconfig/nfs ?:
> Config changes to /etc/sysconfig/nfs:
> MOUNTD_NFS_V2="yes"
> RPCNFSDARGS="-V 2"
> RPCMOUNTDOPTS="-V 2"
> 2. Do you know if CentOS 8 continues to support NFSv2, even if you have to configure it?
> 3. Do you know if/when we'll hit a hard stop with NFS v2 support on CentOS?
> 4. Gemini may be able to find some funding for the development of an NFSv3 client on RTEMS. Are other sites interested in pursuing this and sharing the cost?
> Aloha,
> -Matt Rippa
> [1] https://bugzilla.redhat.com/show_bug.cgi?id=1452461
Re: Standard RTEMS NFSv3 client Johnson, Andrew N. via Tech-talk
Standard RTEMS NFSv3 client Matt Rippa via Tech-talk
Re: Standard RTEMS NFSv3 client Heinz Junkes via Tech-talk
Prev: RE: send/receive waveform over network. Mark Rivers via Tech-talk
Next: New To Epics - Need Help starting first IOC Kevan Anderson via Tech-talk
Prev: Re: Standard RTEMS NFSv3 client Heinz Junkes via Tech-talk
Next: Re: Standard RTEMS NFSv3 client Johnson, Andrew N. via Tech-talk
