1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: New To Epics - Need Help starting first IOC
From: Kevan Anderson via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 12 Feb 2020 16:12:53 -0800
Mark,
thanks for getting back to me.
Yes I created the softioc directory.
the windows.bat file is the one in /startup/
I typed Gmake as was recommended in the startup directions I had. It compiled the base package.
SOLVED:
Nowhere in the 3 different guides did it say to include the path to the created binary directory after compile. I added
C:\epics\basexxx\bin\windows-x64-debug to the system path and it worked.
Thanks for the suggestion.
Kevan
Kevan Anderson
Beamline Controls Engineering
Advanced Light Source
Lawrence Berkeley National Laboratory
x5407
On Wed, Feb 12, 2020 at 3:10 PM Mark Rivers <rivers at cars.uchicago.edu> wrote:
Hi Kevan,
Did you manually create the softioc directory and put sum.cmd and sum.db in it?
What is your PATH, i.e. where is Windows supposed to find the softioc executable that you invoked?
What is the “window.bat” file that you ran, is it base-7.0.3.1/startup/windows.bat?  If so, that just sets up your Windows system to build EPICS base.  Did you actually build it by typing “make” in base-7.0.3.1 top-level directory?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Mark Rivers via Tech-talk
Sent: Wednesday, February 12, 2020 5:01 PM
To: 'Kevan Anderson' <kevananderson at lbl.gov>
Cc: tech-talk at aps.anl.gov
Subject: RE: New To Epics - Need Help starting first IOC
Hi Kevan,
How did you download epics base from the Web?
You appear to have a directory called C:\epics\base-7.0.3.1\softioc.  Where did that directory come from?
This is the contents of the base-7.0.3.1 directory on my system after I have built it.
H:\epics\base-7.0.3.1>dir
Volume in drive H is local_rw
Volume Serial Number is 6DDD-530A
Directory of H:\epics\base-7.0.3.1
12/23/2019  09:51 AM    <DIR>          .
12/23/2019  09:50 AM    <DIR>          ..
12/04/2017  11:22 AM             4,710 LICENSE
12/04/2017  11:22 AM               782 Makefile
12/24/2019  01:50 PM    <DIR>          configure
12/23/2019  09:43 AM    <DIR>          documentation
02/02/2020  11:20 AM    <DIR>          modules
12/04/2017  11:22 AM    <DIR>          src
01/08/2019  05:12 PM    <DIR>          startup
12/04/2017  11:22 AM    <DIR>          test
02/06/2018  05:55 PM               983 README
12/23/2019  09:52 AM    <DIR>          cfg
12/24/2019  01:50 PM    <DIR>          lib
12/24/2019  01:50 PM    <DIR>          bin
02/02/2020  11:22 AM    <DIR>          html
12/23/2019  09:51 AM    <DIR>          templates
02/02/2020  11:22 AM    <DIR>          include
02/02/2020  11:23 AM    <DIR>          dbd
02/02/2020  11:22 AM    <DIR>          db
               3 File(s)          6,475 bytes
              16 Dir(s)  707,245,117,440 bytes free
Note that there is no softioc directory?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Kevan Anderson via Tech-talk
Sent: Wednesday, February 12, 2020 3:12 PM
To: tech-talk at aps.anl.gov
Subject: New To Epics - Need Help starting first IOC
I downloaded epics base from the web and am trying to compile it and run it on windows 10 x64.
This is the problem I am having when I try to start a soft IOC.
I have grep searched the entire code base in c:\epics and found two locations where "base-3.14" exist. Neither of them help much.
As you can see, I downloaded 7.0.3.1, not 3.14...
Also, my PC does not have a D drive?
The file sum.cmd and associated .db come from here:
I have only installed the base package - run the window.bat, and configured my path to visual studio. Please note, this is unlikely a misconfiguration in a config file, because i grepped the whole folder.
Appreciate your help pointing me to next steps.
Kevan
Kevan Anderson
x5407
New To Epics - Need Help starting first IOC Kevan Anderson via Tech-talk
RE: New To Epics - Need Help starting first IOC Mark Rivers via Tech-talk
Prev: RE: New To Epics - Need Help starting first IOC Mark Rivers via Tech-talk
Next: Re: Standard RTEMS NFSv3 client Ricardo Cardenes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Next: Basler Cameras Support in Area Detector Abdalla Ahmad via Tech-talk
ANJ, 13 Feb 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
