I am trying to compile ADAravis on Ubuntu 18.04 and am running into some difficulties. I'm using the following package versions:
epics base-3.15.6 asyn-R4-38 areaDetector-master branch from GitHub ADGenICam-master branch from GitHub ADAravis-master branch from GitHub I installed all prerequisites for the aravis library and compiled aravis 0.7.2 in my /usr/local directory using meson; version 0.7.3 has some header files with function definitions that are incompatible with the master branch of ADAravis because they require additional inputs (e.g. arvcamera.h defines arv_camera_stop_acquisition (ArvCamera *camera, GError **error) whereas the function call in ADAravis.cpp only provides 'ArvCamera' as an input). I can get ADGenIcam to compile without any problems. Then when I try to compile ADAravis, I get the following output: /opt/epics/synApps/support/areaDetector-master/ADAravis# make clean && makemake -C ./configure clean make[1]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/configure' rm -rf O.linux-x86_64 O.Common make[1]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/configure' make -C ./aravisApp clean make[1]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp' make -C ./src clean make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp/src' rm -rf O.linux-x86_64 O.Common make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp/src' make -C ./Db clean make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp/Db' rm -rf O.linux-x86_64 O.Common make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp/Db' make -C ./op clean make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp/op' make[2]: Nothing to be done for 'clean'. make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp/op' make[1]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp' make -C ./iocs clean make[1]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs' make -C ./aravisIOC clean make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC' make -C ./configure clean make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/configure' rm -rf O.linux-x86_64 O.Common make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/configure' make -C ./aravisApp clean make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/aravisApp' make -C ./src clean make[4]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/aravisApp/src' rm -rf O.linux-x86_64 O.Common make[4]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/aravisApp/src' make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/aravisApp' make -C ./iocBoot clean make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/iocBoot' make -C ./iocAravis clean make[4]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/iocBoot/iocAravis' make[4]: Nothing to be done for 'clean'. make[4]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/iocBoot/iocAravis' make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/iocBoot' make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC' make[1]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs' make -C ./configure install make[1]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/configure' perl -CSD /opt/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../.. mkdir O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../.. \ T_A=linux-x86_64 install make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/configure/O.linux-x86_64' perl -CSD /opt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/configure/O.linux-x86_64' make[1]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/configure' make -C ./aravisApp install make[1]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp' make -C ./src install make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp/src' perl -CSD /opt/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../.. mkdir O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \ T_A=linux-x86_64 install make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp/src/O.linux-x86_64' /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/opt/epics/synApps/support/asyn-R4-38/include -I/opt/epics/synApps/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps/support/areaDetector-master/ADSupport/include -I/opt/epics/synApps/support/areaDetector-master/ADCore/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include -I/opt/epics/synApps/support/areaDetector-master/ADGenICam/include -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/local/include/aravis-0.8 -MM -MF ADAravis.d ../ADAravis.cpp /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/opt/epics/synApps/support/asyn-R4-38/include -I/opt/epics/synApps/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps/support/areaDetector-master/ADSupport/include -I/opt/epics/synApps/support/areaDetector-master/ADCore/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include -I/opt/epics/synApps/support/areaDetector-master/ADGenICam/include -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/local/include/aravis-0.8 -MM -MF arvFeature.d ../arvFeature.cpp /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/opt/epics/synApps/support/asyn-R4-38/include -I/opt/epics/synApps/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps/support/areaDetector-master/ADSupport/include -I/opt/epics/synApps/support/areaDetector-master/ADCore/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include -I/opt/epics/synApps/support/areaDetector-master/ADGenICam/include -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/local/include/aravis-0.8 -c ../arvFeature.cpp /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/opt/epics/synApps/support/asyn-R4-38/include -I/opt/epics/synApps/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps/support/areaDetector-master/ADSupport/include -I/opt/epics/synApps/support/areaDetector-master/ADCore/include -I/opt/epics/base/include/compiler/gcc -I/opt/epics/base/include/os/Linux -I/opt/epics/base/include -I/opt/epics/synApps/support/areaDetector-master/ADGenICam/include -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/local/include/aravis-0.8 -c ../ADAravis.cpp /usr/bin/ar -rc libADAravis.a arvFeature.o ADAravis.o /usr/bin/ranlib libADAravis.a make[3]: *** No rule to make target '../../../lib/linux-x86_64/libglib-2.0.a', needed by 'libADAravis.so'. Stop. make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp/src/O.linux-x86_64' /opt/epics/base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp/src' /opt/epics/base/configure/RULES_DIRS:84: recipe for target 'src.install' failed make[1]: *** [src.install] Error 2 make[1]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADAravis/aravisApp' /opt/epics/base/configure/RULES_DIRS:84: recipe for target 'aravisApp.install' failed make: *** [aravisApp.install] Error 2 Libglib-2.0.a exists, but it lives in /usr/lib/x86_64-linux-gnu/libglib-2.0.a. I have tried creating a folder in ADAravis/lib/linux-x86_64 and making a symlink to the x86_64-linux-gnu directory, but then I get a different set of errors, namely: /opt/epics/synApps/support/areaDetector-master/ADSupport/lib/linux-x86_64/libcoders.so: undefined reference to `xmlNanoHTTPFrameState'/opt/epics/synApps/support/areaDetector-master/ADSupport/lib/linux-x86_64/libcoders.so: undefined reference to `xmlNanoHTTPStreaming' Any help is appreciated and please let me know if you need any more info. Thanks so much, Katie
ANJ, 21 Feb 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
