Subject: Re: MRF Delay Compensation Function
From: "Shen, Guobao via Tech-talk" <[email protected]>
To: "Wang, Lin" <[email protected]>
Date: Wed, 19 Feb 2020 02:43:12 +0000
Hi Lin,
How is everything at CSNS?
That is good that you did get a chance to have a simple test.
During your test, did you observe any jitter issue?
Were you able to turn on and off the delay compensation function smoothly?
Or do you have to go with a work around solution, for example leaving the compensation function on and putting zero delay there?
When you disable the delay compensation, how about the signal quality? Any performance issue?
Guobao
Sent: Tuesday, February 18, 2020 7:59:54 PM
To: Shen, Guobao <[email protected]>
Hi Guobao,
In 2018, in the task of event timing system prototype of the HEPS-TF project, I built a test stand with MRF VME-EVM-300 and VME-EVR-300, and did a simple test of the delay compensation function.
Hardware platform:
MVME-5100
VME-EVM-300
VME-EVR-300
Software platform:
Debian 8.7 32-bit running in VirtualBox
vxWorks 6.8
PSI fork of mrfioc2 [1]
EPICS-3.14.12.3
devlib2-2.8
The caQtDM OPI (included in mrfioc2) developed by PSI was very straightforward and contained everything I wanted. I enabled the delay compensation mode in both VME-EVM-300 and VME-EVR-300 as well as some other configurations, and set a appropriate delay compensation target value to VME-EVR-300, then the internal FIFO in VME-EVR-300 did the compensation.
Actually, the only test I did was switching optical fiber from 3 meter to 6 meter, and it turned out that the compensation function worked properly. Due to my work assignment, I did not do any further test since then. Shortly, I will send you a memo document written in Chinese which records my test procedure.
Lin
[1] https://github.com/paulscherrerinstitute/mrfioc2
-----Original Messages-----
From:"Shen, Guobao via Tech-talk" <[email protected]>
Sent Time:2020-02-19 02:43:22 (Wednesday)
To: Tech-Talk <[email protected]>
Cc:
Subject: MRF Delay Compensation Function
Hi all,
Is there anyone who has been using MRF EVM-300 delay compensation function for any purpose, in the lab, test stand, real machine, etc?
If yes, would you mind to share us your experience?
Guobao
Guobao Shen
[email protected]
Controls Group Leader
Advanced Photon Source
Argonne National Laboratory
9700 S. Cass Avenue, Lemont, IL 60439
Re: MRF Delay Compensation Function Wang, Lin via Tech-talk
MRF Delay Compensation Function Shen, Guobao via Tech-talk
Prev: Re: MRF Delay Compensation Function Wang, Lin via Tech-talk
Next: Re: MRF Delay Compensation Function Wang, Lin via Tech-talk
