1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: Buffer full issue with ADAravis
From: Katie Matusik via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 21 Feb 2020 13:35:24 -0800
Hi Mark,
Please find the output attached.
Thank you!
Katie
On Fri, Feb 21, 2020 at 1:15 PM Mark Rivers <rivers at cars.uchicago.edu> wrote:
Hi Katie,
That output does not show what I want.
Please do the following:
-          Comment out the asynSetTraceMask line in the startup script again
-          Boot the IOC
-          Once it is done booting type that asynSetTraceMask command interactively on the command line
-          Press the Acquire button
-          Let it run for a few seconds and then type exit.
Send me the output.
Sent: Friday, February 21, 2020 1:19 PM
Hi Mark,
When I press "acquire", I don't get any output in the iocsh console. I'm attaching a text file of the console output when asyntrace is enabled; I truncated at some point and am hopefully providing you with the relevant info. For wc, I get  2161 3959 58969 Teledyne_ShadoBox.template; when I use the original script version (i.e. remove "IntReg"), then I recover your exact output:  2119  3881 57783 GenICamApp/Db/Teledyne_ShadoBox.template.
Thanks so much,
Katie
On Fri, Feb 21, 2020 at 10:19 AM Mark Rivers <rivers at cars.uchicago.edu> wrote:
Hi Katie,
Ø  I should mention that I made two changes to makeDb.py in order for it to generate the database file:  line 26 was changed to specify the encoding type, "genicam_lines = open(args[0], encoding="utf-8").readlines()" otherwise it threw an error (I'm using python v3.6.9),
I am using Python 3.7.3 and I did not get that error on the xml you attached to your previous message.  This is what I see when I run addCamera, which runs makeDb.py and makeAdl.py.
corvette:~/devel/areaDetector/ADGenICam>./addCamera.sh Teledyne_ShadoBox
Don't know what to do with IntReg
More than 16 enum entries for GevSupportedOptionSelector mbbi record, discarding additional options.
   If needed, edit the Enumeration tag for GevSupportedOptionSelector to select the 16 you want.
Don't know what to do with Register
Ø  and I added "IntReg" to the list of data types in line 145, "if node.nodeName in ["Integer", "IntConverter", "IntSwissKnife", "IntReg"]:".
I do see messages that say “Don't know what to do with IntReg”, but I think they are harmless, just as the ones that say “Don't know what to do with Register”.  This is what I get running “wc” on the resulting .template file.
corvette:~/devel/areaDetector/ADGenICam>wc GenICamApp/Db/Teledyne_ShadoBox.template
What do you get?
Sent: Friday, February 21, 2020 12:03 PM
To: 'Katie Matusik' <kmatusik at sigray.com>
Subject: RE: Buffer full issue with ADAravis
Hi Katie,
Ø  When I press acquire, the buffer again immediately fills up and neither the values in the "Status" box nor in the stats plugin change.
The buffer is not actually “filling up”.  It does indicate that 20 NDArrays have been allocated, totaling 114.3 MB.  Your arrays are 2304x1300 pixels, presumably 2-bytes per pixel, which is  5.71 MB per array.  20 arrays would be 114.3 MB, which is excactly what it says it allocated.
When you press Acquire are there any messages on the iocsh console?
It looks like the ADAravis driver is allocating NDArrays, but it is never doing callbacks, and never realizing that acquisition is complete.
We are going to need to enable some debugging to figure out why.
The first thing to do is to enable all asynTrace information from the driver.  In your startup script uncomment this line after aravisConfig():
asynSetTraceMask($(PORT), 0, TRACE_ERROR|TRACEIO_DRIVER|TRACE_FLOW)
If that does not provide enough information you will need to add some more asynPrint statements in the driver to track down what is going wrong.
Sent: Friday, February 21, 2020 10:54 AM
Hi Mark,
Please see attached for the plugins/all and statistics screens, as well as the xml file. The pixel format options are mono14 and mono12packed. I changed the status rate to 1 second and enabled the statistics plugin. When I press acquire, the buffer again immediately fills up and neither the values in the "Status" box nor in the stats plugin change. I should mention that I made two changes to makeDb.py in order for it to generate the database file:  line 26 was changed to specify the encoding type, "genicam_lines = open(args[0], encoding="utf-8").readlines()" otherwise it threw an error (I'm using python v3.6.9), and I added "IntReg" to the list of data types in line 145, "if node.nodeName in ["Integer", "IntConverter", "IntSwissKnife", "IntReg"]:".
Thanks so much,
Katie
Image removed by sender.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Katie Matusik
Systems Engineer
5750 Imhoff Drive, Suite I
Concord, CA 94520 USA
Office: 1 (925) 326 - 7926
Katie Matusik
Systems Engineer
epics> asynSetTraceMask($(PORT), 0, TRACE_ERROR|TRACEIO_DRIVER|TRACE_FLOW)
2020/02/21 21:28:34.598 ARV1:cam1:AsynIO: exception 3, asynExceptionTraceMask
epics> 2020/02/21 21:28:34.697 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:34.697 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:34.698 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:34.698 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:34.698 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:34.698 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:34.698 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:34.797 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:34.797 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:34.797 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:34.798 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:34.798 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:34.798 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:34.798 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:34.798 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 21:28:34.798 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:34.798 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:34.798 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:34.798 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 21:28:34.798 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 21:28:34.798 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:34.798 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:34.798 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:34.801 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:34.801 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 21:28:34.801 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 21:28:34.801 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 21:28:34.801 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 21:28:34.801 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 21:28:34.801 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 21:28:34.801 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 21:28:34.801 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 21:28:34.801 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 21:28:34.801 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 21:28:34.801 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 21:28:34.801 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:34.801 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 21:28:34.801 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 21:28:34.801 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 21:28:34.801 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:34.801 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 21:28:34.801 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 21:28:34.801 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 21:28:34.801 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 21:28:34.801 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 21:28:34.801 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 21:28:34.801 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 21:28:34.801 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 21:28:34.801 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 21:28:34.801 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 21:28:34.801 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 21:28:34.801 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 21:28:34.802 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 21:28:34.802 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 21:28:34.802 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 21:28:34.802 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 21:28:34.802 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 21:28:34.802 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 21:28:34.802 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 21:28:34.802 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 21:28:34.802 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:34.804 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 21:28:34.804 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 21:28:34.804 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 21:28:34.804 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 21:28:34.804 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 21:28:34.804 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 21:28:34.804 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 21:28:34.804 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 21:28:34.804 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 21:28:34.804 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 21:28:34.804 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 21:28:34.804 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 21:28:34.804 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:34.804 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 21:28:34.804 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 21:28:34.804 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 21:28:34.804 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 21:28:34.804 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 21:28:34.804 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 21:28:34.804 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 21:28:34.804 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 21:28:34.804 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 21:28:34.804 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 21:28:34.804 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 21:28:34.805 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 21:28:34.805 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 21:28:34.805 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 21:28:34.805 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 21:28:34.805 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 21:28:34.805 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 21:28:34.805 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 21:28:34.805 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 21:28:34.805 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 21:28:34.805 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 21:28:34.805 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 21:28:34.805 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 21:28:34.805 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 21:28:34.805 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 21:28:34.805 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 21:28:34.805 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 21:28:34.805 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 21:28:34.805 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 21:28:34.805 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 21:28:34.805 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 21:28:34.805 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 21:28:34.805 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 21:28:34.805 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 21:28:34.805 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 21:28:34.805 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 21:28:34.805 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 21:28:34.805 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 21:28:34.805 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 21:28:34.805 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 21:28:34.805 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 21:28:34.805 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 21:28:34.805 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 21:28:34.805 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 21:28:34.805 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 21:28:34.805 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 21:28:34.805 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 21:28:34.805 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 21:28:34.805 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 21:28:34.805 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 21:28:34.805 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 21:28:34.805 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 21:28:34.805 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 21:28:34.805 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 21:28:34.805 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 21:28:34.805 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 21:28:34.805 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 21:28:34.805 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 21:28:34.805 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 21:28:34.805 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 21:28:34.805 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 21:28:34.805 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 21:28:34.805 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 21:28:34.805 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 21:28:34.805 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 21:28:34.805 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 21:28:34.805 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 21:28:34.805 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 21:28:34.805 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 21:28:34.805 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 21:28:34.805 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 21:28:34.805 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 21:28:34.805 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 21:28:34.805 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 21:28:34.806 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:34.806 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:34.806 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 21:28:34.806 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 21:28:34.806 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 21:28:34.806 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:34.806 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 21:28:34.806 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 21:28:34.806 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 21:28:34.806 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 21:28:34.806 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 21:28:34.806 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 21:28:34.806 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 21:28:34.806 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 21:28:34.806 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 21:28:34.806 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:34.897 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:34.898 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:34.898 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:34.898 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:34.898 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:34.898 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:34.997 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:34.997 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:34.998 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:34.998 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:34.998 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:34.998 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:34.998 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:35.097 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.097 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.097 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:35.098 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.098 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.098 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:35.098 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:35.197 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.197 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.198 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:35.198 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.198 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.198 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:35.198 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:35.297 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.297 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.298 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:35.298 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.298 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.298 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:35.298 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:35.397 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.397 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.398 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:35.398 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.398 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.398 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:35.398 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:35.497 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.497 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.497 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:35.498 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.498 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.498 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:35.498 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:35.597 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.597 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.598 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:35.598 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.598 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.598 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:35.598 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:35.697 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.698 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.698 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:35.698 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.698 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:35.698 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:35.797 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.797 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.797 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:35.798 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.798 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.798 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:35.798 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:35.798 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 21:28:35.798 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:35.798 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:35.798 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:35.798 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 21:28:35.798 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 21:28:35.798 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:35.798 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:35.798 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:35.801 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:35.801 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 21:28:35.801 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 21:28:35.801 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 21:28:35.801 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 21:28:35.801 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 21:28:35.801 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 21:28:35.801 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 21:28:35.801 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 21:28:35.801 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 21:28:35.801 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 21:28:35.801 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 21:28:35.801 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:35.801 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 21:28:35.801 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 21:28:35.801 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 21:28:35.801 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:35.801 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 21:28:35.801 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 21:28:35.801 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 21:28:35.801 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 21:28:35.801 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 21:28:35.801 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 21:28:35.801 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 21:28:35.801 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 21:28:35.801 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 21:28:35.802 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 21:28:35.802 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 21:28:35.802 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 21:28:35.802 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 21:28:35.802 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 21:28:35.802 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 21:28:35.802 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 21:28:35.802 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 21:28:35.802 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 21:28:35.802 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 21:28:35.802 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 21:28:35.802 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:35.804 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 21:28:35.804 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 21:28:35.804 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 21:28:35.804 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 21:28:35.805 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 21:28:35.805 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 21:28:35.805 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 21:28:35.805 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 21:28:35.805 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 21:28:35.805 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 21:28:35.805 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 21:28:35.805 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 21:28:35.805 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:35.805 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 21:28:35.805 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 21:28:35.805 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 21:28:35.805 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 21:28:35.805 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 21:28:35.805 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 21:28:35.805 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 21:28:35.805 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 21:28:35.805 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 21:28:35.805 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 21:28:35.805 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 21:28:35.805 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 21:28:35.805 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 21:28:35.805 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 21:28:35.805 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 21:28:35.805 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 21:28:35.805 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 21:28:35.805 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 21:28:35.805 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 21:28:35.805 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 21:28:35.805 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 21:28:35.805 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 21:28:35.805 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 21:28:35.805 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 21:28:35.805 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 21:28:35.805 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 21:28:35.805 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 21:28:35.805 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 21:28:35.805 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 21:28:35.805 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 21:28:35.805 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 21:28:35.805 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 21:28:35.805 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 21:28:35.805 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 21:28:35.805 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 21:28:35.805 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 21:28:35.805 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 21:28:35.806 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 21:28:35.806 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 21:28:35.806 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 21:28:35.806 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 21:28:35.806 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 21:28:35.806 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 21:28:35.806 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 21:28:35.806 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 21:28:35.806 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 21:28:35.806 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 21:28:35.806 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 21:28:35.806 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 21:28:35.806 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 21:28:35.806 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 21:28:35.806 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 21:28:35.806 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 21:28:35.806 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 21:28:35.806 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 21:28:35.806 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 21:28:35.806 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 21:28:35.806 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 21:28:35.806 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 21:28:35.806 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 21:28:35.806 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 21:28:35.806 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 21:28:35.806 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 21:28:35.806 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 21:28:35.806 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 21:28:35.806 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 21:28:35.806 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 21:28:35.806 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 21:28:35.806 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 21:28:35.806 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 21:28:35.806 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 21:28:35.806 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 21:28:35.806 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 21:28:35.806 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 21:28:35.806 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:35.806 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:35.806 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 21:28:35.806 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 21:28:35.806 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 21:28:35.806 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:35.806 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 21:28:35.806 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 21:28:35.806 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 21:28:35.806 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 21:28:35.806 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 21:28:35.806 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 21:28:35.806 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 21:28:35.806 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 21:28:35.806 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 21:28:35.806 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.897 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.898 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.898 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:35.898 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.898 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:35.898 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:35.997 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.997 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.998 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:35.998 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:35.998 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:35.998 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:35.998 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:36.097 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.098 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.098 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:36.098 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.098 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:36.098 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:36.197 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.197 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.198 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:36.198 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.198 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.198 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:36.198 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:36.294 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.294 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.294 asynNDArrayDriver:writeInt32: function=8, paramName=ACQUIRE, value=1
2020/02/21 21:28:36.294 ADDriver:writeInt32: function=8, paramName=ACQUIRE, value=1
2020/02/21 21:28:36.297 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.343 ADGenICam::writeInt32 function=8, value=1, status=0
2020/02/21 21:28:36.343 ADAravis:writeInt32: function=8 ACQUIRE, value=1
2020/02/21 21:28:36.343 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.343 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:36.343 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.343 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:36.343 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:36.397 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.397 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.397 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:36.398 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.398 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.398 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:36.398 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:36.497 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.497 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.497 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:36.498 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.498 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.498 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:36.498 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:36.597 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.597 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.598 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:36.598 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.598 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.598 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:36.598 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:36.697 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.698 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.698 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:36.698 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.698 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:36.698 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:36.797 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.797 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.797 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:36.798 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.798 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.798 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:36.798 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:36.798 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 21:28:36.798 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:36.798 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:36.798 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:36.798 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 21:28:36.798 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 21:28:36.798 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:36.798 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:36.798 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:36.801 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:36.801 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 21:28:36.801 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 21:28:36.801 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 21:28:36.801 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 21:28:36.801 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 21:28:36.801 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 21:28:36.801 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 21:28:36.801 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 21:28:36.801 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 21:28:36.801 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 21:28:36.801 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 21:28:36.801 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:36.801 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 21:28:36.801 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 21:28:36.801 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 21:28:36.801 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:36.801 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 21:28:36.801 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 21:28:36.801 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 21:28:36.801 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 21:28:36.801 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 21:28:36.801 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 21:28:36.801 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 21:28:36.801 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 21:28:36.801 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 21:28:36.802 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 21:28:36.802 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 21:28:36.802 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 21:28:36.802 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 21:28:36.802 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 21:28:36.802 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 21:28:36.802 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 21:28:36.802 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 21:28:36.802 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 21:28:36.802 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 21:28:36.802 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 21:28:36.802 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:36.804 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 21:28:36.804 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 21:28:36.804 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 21:28:36.804 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 21:28:36.804 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 21:28:36.804 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 21:28:36.804 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 21:28:36.804 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 21:28:36.804 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 21:28:36.804 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 21:28:36.804 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 21:28:36.804 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 21:28:36.804 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:36.804 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 21:28:36.804 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 21:28:36.804 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 21:28:36.804 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 21:28:36.804 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 21:28:36.805 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 21:28:36.805 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 21:28:36.805 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 21:28:36.805 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 21:28:36.805 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 21:28:36.805 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 21:28:36.805 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 21:28:36.805 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 21:28:36.805 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 21:28:36.805 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 21:28:36.805 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 21:28:36.805 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 21:28:36.805 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 21:28:36.805 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 21:28:36.805 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 21:28:36.805 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 21:28:36.805 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 21:28:36.805 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 21:28:36.805 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 21:28:36.805 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 21:28:36.805 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 21:28:36.805 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 21:28:36.805 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 21:28:36.805 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 21:28:36.805 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 21:28:36.805 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 21:28:36.805 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 21:28:36.805 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 21:28:36.805 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 21:28:36.805 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 21:28:36.805 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 21:28:36.805 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 21:28:36.805 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 21:28:36.805 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 21:28:36.805 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 21:28:36.805 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 21:28:36.805 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 21:28:36.805 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 21:28:36.805 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 21:28:36.805 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 21:28:36.805 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 21:28:36.805 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 21:28:36.805 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 21:28:36.805 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 21:28:36.805 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 21:28:36.805 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 21:28:36.805 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 21:28:36.805 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 21:28:36.805 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 21:28:36.805 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 21:28:36.805 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 21:28:36.805 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 21:28:36.805 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 21:28:36.805 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 21:28:36.806 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 21:28:36.806 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 21:28:36.806 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 21:28:36.806 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 21:28:36.806 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 21:28:36.806 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 21:28:36.806 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 21:28:36.806 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 21:28:36.806 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 21:28:36.806 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 21:28:36.806 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 21:28:36.806 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 21:28:36.806 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 21:28:36.806 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 21:28:36.806 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 21:28:36.806 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:36.806 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:36.806 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 21:28:36.806 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 21:28:36.806 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 21:28:36.806 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:36.806 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 21:28:36.806 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 21:28:36.806 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 21:28:36.806 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 21:28:36.806 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 21:28:36.806 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 21:28:36.806 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 21:28:36.806 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 21:28:36.806 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 21:28:36.806 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.897 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.898 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.898 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:36.898 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.898 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:36.898 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:36.997 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.997 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.998 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:36.998 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.998 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.998 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:36.998 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:37.097 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.097 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.098 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:37.098 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.098 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.098 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:37.098 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:37.197 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.197 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.198 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:37.198 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.198 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.198 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:37.198 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:37.297 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.297 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.298 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:37.298 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.298 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.298 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:37.298 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:37.397 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.397 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.398 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:37.398 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.398 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.398 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:37.398 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:37.497 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.497 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.497 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:37.498 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.498 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.498 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:37.498 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:37.597 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.597 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.598 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:37.598 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.598 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.598 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:37.598 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:37.697 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.698 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.698 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:37.698 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.698 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:37.698 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:37.797 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.797 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.797 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:37.798 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.798 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.798 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:37.798 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:37.798 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 21:28:37.798 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:37.798 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:37.798 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:37.798 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 21:28:37.798 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 21:28:37.798 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:37.798 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:37.798 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:37.801 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:37.801 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 21:28:37.801 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 21:28:37.801 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 21:28:37.801 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 21:28:37.801 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 21:28:37.801 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 21:28:37.801 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 21:28:37.801 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 21:28:37.801 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 21:28:37.801 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 21:28:37.801 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 21:28:37.801 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:37.801 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 21:28:37.801 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 21:28:37.801 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 21:28:37.801 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:37.801 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 21:28:37.801 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 21:28:37.801 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 21:28:37.802 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 21:28:37.802 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 21:28:37.802 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 21:28:37.802 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 21:28:37.802 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 21:28:37.802 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 21:28:37.802 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 21:28:37.802 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 21:28:37.802 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 21:28:37.802 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 21:28:37.802 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 21:28:37.802 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 21:28:37.802 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 21:28:37.802 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 21:28:37.802 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 21:28:37.802 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 21:28:37.802 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 21:28:37.802 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:37.805 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 21:28:37.805 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 21:28:37.805 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 21:28:37.805 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 21:28:37.805 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 21:28:37.805 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 21:28:37.805 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 21:28:37.805 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 21:28:37.805 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 21:28:37.805 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 21:28:37.805 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 21:28:37.805 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 21:28:37.805 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:37.805 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 21:28:37.805 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 21:28:37.805 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 21:28:37.805 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 21:28:37.805 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 21:28:37.805 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 21:28:37.805 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 21:28:37.805 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 21:28:37.805 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 21:28:37.805 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 21:28:37.805 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 21:28:37.805 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 21:28:37.805 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 21:28:37.805 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 21:28:37.805 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 21:28:37.805 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 21:28:37.805 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 21:28:37.805 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 21:28:37.805 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 21:28:37.805 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 21:28:37.805 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 21:28:37.805 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 21:28:37.805 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 21:28:37.805 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 21:28:37.806 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 21:28:37.806 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 21:28:37.806 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 21:28:37.806 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 21:28:37.806 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 21:28:37.806 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 21:28:37.806 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 21:28:37.806 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 21:28:37.806 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 21:28:37.806 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 21:28:37.806 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 21:28:37.806 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 21:28:37.806 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 21:28:37.806 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 21:28:37.806 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 21:28:37.806 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 21:28:37.806 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 21:28:37.806 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 21:28:37.806 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 21:28:37.806 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 21:28:37.806 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 21:28:37.806 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 21:28:37.806 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 21:28:37.806 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 21:28:37.806 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 21:28:37.806 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 21:28:37.806 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 21:28:37.806 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 21:28:37.806 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 21:28:37.806 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 21:28:37.806 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 21:28:37.806 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 21:28:37.806 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 21:28:37.806 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 21:28:37.806 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 21:28:37.806 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 21:28:37.806 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 21:28:37.806 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 21:28:37.806 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 21:28:37.806 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 21:28:37.806 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 21:28:37.806 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 21:28:37.806 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 21:28:37.806 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 21:28:37.806 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 21:28:37.806 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 21:28:37.806 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 21:28:37.806 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 21:28:37.806 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 21:28:37.806 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 21:28:37.806 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:37.806 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:37.807 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 21:28:37.807 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 21:28:37.807 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 21:28:37.807 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:37.807 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 21:28:37.807 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 21:28:37.807 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 21:28:37.807 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 21:28:37.807 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 21:28:37.807 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 21:28:37.807 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 21:28:37.807 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 21:28:37.807 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 21:28:37.807 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.897 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.898 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.898 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:37.898 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.898 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:37.898 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:37.997 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.997 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.998 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:37.998 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:37.998 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:37.998 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:37.998 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:38.097 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.098 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.098 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:38.098 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.098 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:38.098 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:38.197 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.197 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.198 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:38.198 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.198 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.198 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:38.198 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:38.297 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.297 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.298 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:38.298 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.298 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.298 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:38.298 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:38.397 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.397 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.398 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:38.398 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.398 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.398 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:38.398 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:38.497 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.497 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.498 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:38.498 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.498 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.498 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:38.498 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:38.597 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.597 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.598 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:38.598 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.598 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.598 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:38.598 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:38.697 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.698 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.698 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:38.698 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.698 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:38.698 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:38.797 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.797 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.798 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:38.798 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.798 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.798 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:38.798 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:38.798 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 21:28:38.798 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:38.798 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:38.798 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:38.798 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 21:28:38.798 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 21:28:38.798 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:38.798 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:38.798 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:38.801 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:38.801 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 21:28:38.801 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 21:28:38.801 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 21:28:38.801 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 21:28:38.801 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 21:28:38.801 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 21:28:38.801 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 21:28:38.801 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 21:28:38.801 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 21:28:38.801 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 21:28:38.801 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 21:28:38.801 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:38.801 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 21:28:38.801 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 21:28:38.802 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 21:28:38.802 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:38.802 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 21:28:38.802 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 21:28:38.802 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 21:28:38.802 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 21:28:38.802 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 21:28:38.802 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 21:28:38.802 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 21:28:38.802 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 21:28:38.802 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 21:28:38.802 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 21:28:38.802 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 21:28:38.802 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 21:28:38.803 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 21:28:38.803 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 21:28:38.803 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 21:28:38.803 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 21:28:38.803 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 21:28:38.803 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 21:28:38.803 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 21:28:38.803 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 21:28:38.803 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:38.805 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 21:28:38.805 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 21:28:38.805 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 21:28:38.805 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 21:28:38.805 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 21:28:38.806 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 21:28:38.806 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 21:28:38.806 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 21:28:38.806 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 21:28:38.806 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 21:28:38.806 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 21:28:38.806 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 21:28:38.806 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:38.806 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 21:28:38.806 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 21:28:38.806 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 21:28:38.806 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 21:28:38.806 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 21:28:38.806 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 21:28:38.806 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 21:28:38.806 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 21:28:38.806 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 21:28:38.806 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 21:28:38.806 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 21:28:38.806 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 21:28:38.806 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 21:28:38.806 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 21:28:38.806 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 21:28:38.806 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 21:28:38.806 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 21:28:38.806 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 21:28:38.806 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 21:28:38.806 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 21:28:38.806 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 21:28:38.806 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 21:28:38.806 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 21:28:38.806 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 21:28:38.806 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 21:28:38.807 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 21:28:38.807 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 21:28:38.807 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 21:28:38.807 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 21:28:38.807 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 21:28:38.807 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 21:28:38.807 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 21:28:38.807 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 21:28:38.807 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 21:28:38.807 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 21:28:38.807 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 21:28:38.807 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 21:28:38.807 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 21:28:38.807 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 21:28:38.807 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 21:28:38.807 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 21:28:38.807 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 21:28:38.807 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 21:28:38.807 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 21:28:38.807 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 21:28:38.807 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 21:28:38.807 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 21:28:38.807 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 21:28:38.807 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 21:28:38.807 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 21:28:38.807 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 21:28:38.807 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 21:28:38.807 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 21:28:38.807 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 21:28:38.808 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 21:28:38.808 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 21:28:38.808 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 21:28:38.808 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 21:28:38.808 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 21:28:38.808 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 21:28:38.808 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 21:28:38.808 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 21:28:38.808 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 21:28:38.808 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 21:28:38.808 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 21:28:38.808 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 21:28:38.808 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 21:28:38.808 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 21:28:38.808 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 21:28:38.808 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 21:28:38.808 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 21:28:38.808 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 21:28:38.808 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 21:28:38.808 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 21:28:38.808 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:38.808 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:38.808 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 21:28:38.808 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 21:28:38.808 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 21:28:38.808 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:38.808 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 21:28:38.808 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 21:28:38.808 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 21:28:38.808 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 21:28:38.808 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 21:28:38.808 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 21:28:38.808 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 21:28:38.809 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 21:28:38.809 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 21:28:38.809 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.897 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.897 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.897 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:38.898 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.898 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.898 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:38.898 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:38.997 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.997 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.997 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:38.998 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:38.998 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:38.998 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:38.998 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:39.097 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.098 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.098 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:39.098 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.098 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:39.098 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:39.197 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.197 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.197 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:39.198 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.198 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.198 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:39.198 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:39.297 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.298 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.298 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:39.298 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.298 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:39.298 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:39.397 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.397 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.398 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:39.398 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.398 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.398 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:39.398 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:39.497 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.498 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.498 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:39.498 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.498 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:39.498 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:39.597 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.597 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.597 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:39.598 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.598 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.598 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:39.598 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:39.697 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.698 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.698 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:39.698 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.698 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:39.698 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:39.797 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.797 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.797 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:39.798 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.798 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:39.798 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.798 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:39.798 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 21:28:39.798 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:39.798 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:39.798 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:39.798 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 21:28:39.798 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 21:28:39.798 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:39.798 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:39.798 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:39.800 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:39.801 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 21:28:39.801 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 21:28:39.801 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 21:28:39.801 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 21:28:39.801 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 21:28:39.801 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 21:28:39.801 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 21:28:39.801 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 21:28:39.801 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 21:28:39.801 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 21:28:39.801 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 21:28:39.801 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:39.801 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 21:28:39.801 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 21:28:39.801 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 21:28:39.801 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:39.801 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 21:28:39.801 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 21:28:39.801 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 21:28:39.801 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 21:28:39.801 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 21:28:39.801 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 21:28:39.801 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 21:28:39.801 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 21:28:39.801 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 21:28:39.801 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 21:28:39.801 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 21:28:39.801 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 21:28:39.802 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 21:28:39.802 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 21:28:39.802 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 21:28:39.802 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 21:28:39.802 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 21:28:39.802 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 21:28:39.802 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 21:28:39.802 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 21:28:39.802 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:39.804 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 21:28:39.804 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 21:28:39.804 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 21:28:39.804 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 21:28:39.804 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 21:28:39.804 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 21:28:39.804 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 21:28:39.804 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 21:28:39.804 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 21:28:39.804 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 21:28:39.804 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 21:28:39.804 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 21:28:39.804 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:39.804 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 21:28:39.804 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 21:28:39.804 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 21:28:39.804 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 21:28:39.804 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 21:28:39.804 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 21:28:39.804 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 21:28:39.804 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 21:28:39.804 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 21:28:39.804 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 21:28:39.804 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 21:28:39.804 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 21:28:39.804 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 21:28:39.805 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 21:28:39.805 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 21:28:39.805 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 21:28:39.805 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 21:28:39.805 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 21:28:39.805 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 21:28:39.805 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 21:28:39.805 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 21:28:39.805 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 21:28:39.805 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 21:28:39.805 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 21:28:39.805 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 21:28:39.805 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 21:28:39.805 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 21:28:39.805 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 21:28:39.805 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 21:28:39.805 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 21:28:39.805 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 21:28:39.805 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 21:28:39.805 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 21:28:39.805 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 21:28:39.805 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 21:28:39.805 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 21:28:39.805 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 21:28:39.805 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 21:28:39.805 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 21:28:39.805 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 21:28:39.805 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 21:28:39.805 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 21:28:39.805 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 21:28:39.805 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 21:28:39.805 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 21:28:39.805 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 21:28:39.805 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 21:28:39.805 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 21:28:39.805 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 21:28:39.805 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 21:28:39.805 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 21:28:39.805 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 21:28:39.805 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 21:28:39.805 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 21:28:39.805 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 21:28:39.805 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 21:28:39.805 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 21:28:39.805 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 21:28:39.805 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 21:28:39.805 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 21:28:39.805 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 21:28:39.805 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 21:28:39.805 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 21:28:39.805 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 21:28:39.805 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 21:28:39.805 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 21:28:39.805 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 21:28:39.805 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 21:28:39.805 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 21:28:39.805 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 21:28:39.805 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 21:28:39.806 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 21:28:39.806 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 21:28:39.806 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 21:28:39.806 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:39.806 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:39.806 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 21:28:39.806 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 21:28:39.806 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 21:28:39.806 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:39.806 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 21:28:39.806 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 21:28:39.806 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 21:28:39.806 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 21:28:39.806 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 21:28:39.806 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 21:28:39.806 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 21:28:39.806 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 21:28:39.806 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 21:28:39.806 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.897 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.897 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.898 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:39.898 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.898 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.898 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:39.898 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:39.997 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.997 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.998 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:39.998 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:39.998 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:39.998 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:39.998 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:40.097 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.097 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.098 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:40.098 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.098 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.098 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:40.098 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:40.197 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.197 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.198 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:40.198 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.198 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.198 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:40.198 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:40.297 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.297 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.297 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:40.298 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.298 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.298 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:40.298 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:40.397 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.397 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.398 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:40.398 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.398 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.398 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:40.398 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:40.497 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.498 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.498 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:40.498 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.498 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:40.498 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:40.597 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.597 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.598 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:40.598 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.598 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.598 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:40.598 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:40.697 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.697 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.698 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:40.698 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.698 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.698 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:40.698 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:40.797 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.797 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.797 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:40.798 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.798 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:40.798 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.798 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:40.798 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 21:28:40.798 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:40.798 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:40.798 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:40.798 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 21:28:40.798 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 21:28:40.798 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:40.798 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:40.798 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:40.801 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:40.801 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 21:28:40.801 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 21:28:40.801 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 21:28:40.801 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 21:28:40.801 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 21:28:40.801 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 21:28:40.801 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 21:28:40.801 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 21:28:40.801 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 21:28:40.801 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 21:28:40.801 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 21:28:40.801 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:40.801 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 21:28:40.801 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 21:28:40.801 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 21:28:40.801 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:40.801 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 21:28:40.801 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 21:28:40.801 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 21:28:40.801 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 21:28:40.801 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 21:28:40.801 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 21:28:40.801 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 21:28:40.801 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 21:28:40.801 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 21:28:40.802 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 21:28:40.802 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 21:28:40.802 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 21:28:40.802 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 21:28:40.802 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 21:28:40.802 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 21:28:40.802 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 21:28:40.802 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 21:28:40.802 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 21:28:40.802 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 21:28:40.802 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 21:28:40.802 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:40.804 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 21:28:40.804 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 21:28:40.804 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 21:28:40.804 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 21:28:40.804 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 21:28:40.804 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 21:28:40.804 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 21:28:40.804 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 21:28:40.804 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 21:28:40.804 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 21:28:40.804 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 21:28:40.804 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 21:28:40.804 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:40.804 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 21:28:40.804 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 21:28:40.804 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 21:28:40.804 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 21:28:40.804 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 21:28:40.804 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 21:28:40.805 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 21:28:40.805 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 21:28:40.805 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 21:28:40.805 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 21:28:40.805 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 21:28:40.805 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 21:28:40.805 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 21:28:40.805 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 21:28:40.805 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 21:28:40.805 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 21:28:40.805 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 21:28:40.805 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 21:28:40.805 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 21:28:40.805 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 21:28:40.805 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 21:28:40.805 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 21:28:40.805 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 21:28:40.805 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 21:28:40.805 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 21:28:40.805 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 21:28:40.805 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 21:28:40.805 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 21:28:40.805 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 21:28:40.805 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 21:28:40.805 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 21:28:40.805 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 21:28:40.805 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 21:28:40.805 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 21:28:40.805 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 21:28:40.805 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 21:28:40.805 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 21:28:40.805 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 21:28:40.805 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 21:28:40.805 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 21:28:40.805 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 21:28:40.805 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 21:28:40.805 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 21:28:40.805 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 21:28:40.805 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 21:28:40.805 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 21:28:40.805 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 21:28:40.805 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 21:28:40.805 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 21:28:40.805 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 21:28:40.805 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 21:28:40.805 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 21:28:40.805 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 21:28:40.805 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 21:28:40.805 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 21:28:40.805 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 21:28:40.805 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 21:28:40.805 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 21:28:40.805 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 21:28:40.805 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 21:28:40.805 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 21:28:40.805 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 21:28:40.805 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 21:28:40.805 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 21:28:40.805 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 21:28:40.805 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 21:28:40.805 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 21:28:40.805 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 21:28:40.806 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 21:28:40.806 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 21:28:40.806 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 21:28:40.806 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 21:28:40.806 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 21:28:40.806 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 21:28:40.806 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:40.806 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:40.806 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 21:28:40.806 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 21:28:40.806 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 21:28:40.806 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:40.806 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 21:28:40.806 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 21:28:40.806 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 21:28:40.806 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 21:28:40.806 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 21:28:40.806 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 21:28:40.806 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 21:28:40.806 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 21:28:40.806 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 21:28:40.806 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.897 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.898 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.898 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:40.898 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.898 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:40.898 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:40.997 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.997 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.997 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:40.998 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:40.998 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:40.998 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:40.998 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:41.097 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.098 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.098 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:41.098 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.098 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:41.098 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:41.197 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.197 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.197 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:41.198 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.198 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.198 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:41.198 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:41.297 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.298 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.298 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:41.298 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.298 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:41.298 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:41.397 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.397 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.398 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:41.398 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.398 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.398 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:41.398 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:41.497 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.497 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.498 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:41.498 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.498 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.498 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:41.498 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:41.597 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.597 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.598 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:41.598 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.598 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.598 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:41.598 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:41.697 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.698 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.698 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:41.698 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.698 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:41.698 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:41.797 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.797 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.797 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:41.797 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:41.798 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.798 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.798 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:41.798 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 21:28:41.798 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:41.798 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:41.798 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:41.798 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 21:28:41.798 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 21:28:41.798 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:41.798 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:41.798 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:41.800 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:41.800 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 21:28:41.801 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 21:28:41.801 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 21:28:41.801 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 21:28:41.801 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 21:28:41.801 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 21:28:41.801 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 21:28:41.801 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 21:28:41.801 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 21:28:41.801 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 21:28:41.801 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 21:28:41.801 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:41.801 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 21:28:41.801 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 21:28:41.801 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 21:28:41.801 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:41.801 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 21:28:41.801 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 21:28:41.801 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 21:28:41.801 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 21:28:41.801 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 21:28:41.801 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 21:28:41.801 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 21:28:41.801 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 21:28:41.801 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 21:28:41.801 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 21:28:41.801 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 21:28:41.801 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 21:28:41.801 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 21:28:41.801 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 21:28:41.801 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 21:28:41.801 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 21:28:41.801 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 21:28:41.801 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 21:28:41.801 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 21:28:41.801 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 21:28:41.801 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:41.804 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 21:28:41.804 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 21:28:41.804 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 21:28:41.804 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 21:28:41.804 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 21:28:41.804 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 21:28:41.804 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 21:28:41.804 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 21:28:41.804 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 21:28:41.804 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 21:28:41.804 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 21:28:41.804 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 21:28:41.804 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:41.804 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 21:28:41.804 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 21:28:41.804 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 21:28:41.804 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 21:28:41.804 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 21:28:41.804 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 21:28:41.804 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 21:28:41.804 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 21:28:41.804 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 21:28:41.804 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 21:28:41.804 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 21:28:41.804 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 21:28:41.804 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 21:28:41.804 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 21:28:41.804 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 21:28:41.804 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 21:28:41.804 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 21:28:41.804 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 21:28:41.804 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 21:28:41.805 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 21:28:41.805 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 21:28:41.805 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 21:28:41.805 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 21:28:41.805 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 21:28:41.805 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 21:28:41.805 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 21:28:41.805 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 21:28:41.805 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 21:28:41.805 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 21:28:41.805 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 21:28:41.805 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 21:28:41.805 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 21:28:41.805 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 21:28:41.805 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 21:28:41.805 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 21:28:41.805 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 21:28:41.805 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 21:28:41.805 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 21:28:41.805 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 21:28:41.805 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 21:28:41.805 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 21:28:41.805 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 21:28:41.805 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 21:28:41.805 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 21:28:41.805 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 21:28:41.805 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 21:28:41.805 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 21:28:41.805 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 21:28:41.805 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 21:28:41.805 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 21:28:41.805 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 21:28:41.805 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 21:28:41.805 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 21:28:41.805 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 21:28:41.805 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 21:28:41.805 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 21:28:41.805 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 21:28:41.805 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 21:28:41.805 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 21:28:41.805 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 21:28:41.805 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 21:28:41.805 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 21:28:41.805 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 21:28:41.805 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 21:28:41.805 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 21:28:41.805 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 21:28:41.805 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 21:28:41.805 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 21:28:41.805 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 21:28:41.805 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 21:28:41.805 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 21:28:41.805 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 21:28:41.805 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 21:28:41.805 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 21:28:41.805 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:41.805 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:41.805 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 21:28:41.805 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 21:28:41.805 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 21:28:41.805 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:41.805 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 21:28:41.805 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 21:28:41.806 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 21:28:41.806 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 21:28:41.806 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 21:28:41.806 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 21:28:41.806 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 21:28:41.806 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 21:28:41.806 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 21:28:41.806 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.897 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.898 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.898 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:41.898 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.898 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:41.898 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:41.997 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.997 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.997 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:41.998 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:41.998 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:41.998 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:41.998 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:42.097 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.098 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.098 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:42.098 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.098 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:42.098 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:42.197 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.197 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.198 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:42.198 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.198 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.198 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:42.198 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:42.297 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.298 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.298 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:42.298 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.298 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:42.298 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:42.397 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.397 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.398 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:42.398 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.398 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.398 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:42.398 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:42.497 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.498 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.498 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:42.498 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.498 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:42.498 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:42.597 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.597 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.598 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:42.598 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.598 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.598 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:42.598 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:42.697 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.697 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.698 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:42.698 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.698 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.698 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:42.698 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:42.797 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.797 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.797 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:42.798 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.798 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:42.798 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.798 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:42.798 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 21:28:42.798 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:42.798 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:42.798 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:42.798 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 21:28:42.798 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 21:28:42.798 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:42.798 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:42.798 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:42.801 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:42.801 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 21:28:42.801 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 21:28:42.801 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 21:28:42.801 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 21:28:42.801 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 21:28:42.801 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 21:28:42.801 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 21:28:42.801 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 21:28:42.801 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 21:28:42.801 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 21:28:42.801 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 21:28:42.801 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:42.801 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 21:28:42.801 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 21:28:42.801 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 21:28:42.801 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:42.801 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 21:28:42.801 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 21:28:42.801 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 21:28:42.801 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 21:28:42.801 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 21:28:42.801 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 21:28:42.801 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 21:28:42.801 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 21:28:42.801 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 21:28:42.802 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 21:28:42.802 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 21:28:42.802 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 21:28:42.802 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 21:28:42.802 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 21:28:42.802 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 21:28:42.802 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 21:28:42.802 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 21:28:42.802 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 21:28:42.802 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 21:28:42.802 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 21:28:42.802 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:42.804 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 21:28:42.804 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 21:28:42.804 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 21:28:42.804 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 21:28:42.804 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 21:28:42.804 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 21:28:42.804 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 21:28:42.804 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 21:28:42.804 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 21:28:42.804 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 21:28:42.804 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 21:28:42.804 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 21:28:42.804 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:42.804 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 21:28:42.804 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 21:28:42.805 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 21:28:42.805 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 21:28:42.805 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 21:28:42.805 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 21:28:42.805 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 21:28:42.805 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 21:28:42.805 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 21:28:42.805 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 21:28:42.805 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 21:28:42.805 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 21:28:42.805 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 21:28:42.805 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 21:28:42.805 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 21:28:42.805 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 21:28:42.805 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 21:28:42.805 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 21:28:42.805 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 21:28:42.805 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 21:28:42.805 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 21:28:42.805 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 21:28:42.805 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 21:28:42.805 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 21:28:42.805 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 21:28:42.805 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 21:28:42.805 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 21:28:42.805 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 21:28:42.805 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 21:28:42.805 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 21:28:42.805 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 21:28:42.805 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 21:28:42.805 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 21:28:42.805 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 21:28:42.805 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 21:28:42.805 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 21:28:42.805 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 21:28:42.805 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 21:28:42.805 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 21:28:42.805 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 21:28:42.805 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 21:28:42.805 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 21:28:42.805 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 21:28:42.805 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 21:28:42.806 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 21:28:42.806 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 21:28:42.806 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 21:28:42.806 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 21:28:42.806 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 21:28:42.806 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 21:28:42.806 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 21:28:42.806 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 21:28:42.806 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 21:28:42.806 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 21:28:42.806 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 21:28:42.806 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 21:28:42.806 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 21:28:42.806 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 21:28:42.806 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 21:28:42.806 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 21:28:42.806 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 21:28:42.806 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 21:28:42.806 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 21:28:42.806 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 21:28:42.806 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 21:28:42.806 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 21:28:42.806 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 21:28:42.806 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 21:28:42.806 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 21:28:42.806 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 21:28:42.806 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 21:28:42.806 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 21:28:42.806 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 21:28:42.806 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 21:28:42.806 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:42.806 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:42.806 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 21:28:42.806 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 21:28:42.806 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 21:28:42.806 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:42.806 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 21:28:42.806 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 21:28:42.806 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 21:28:42.806 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 21:28:42.806 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 21:28:42.806 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 21:28:42.806 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 21:28:42.806 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 21:28:42.806 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 21:28:42.806 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.897 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.897 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.897 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:42.898 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.898 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.898 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:42.898 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:42.997 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.997 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.998 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:42.998 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:42.998 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:42.998 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:42.998 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:43.097 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.097 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.098 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:43.098 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.098 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.098 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:43.098 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:43.197 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.197 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.198 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:43.198 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.198 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.198 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:43.198 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:43.297 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.298 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.298 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:43.298 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.298 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:43.298 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:43.397 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.397 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.398 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:43.398 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.398 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.398 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:43.398 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:43.497 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.497 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.498 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:43.498 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.498 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.498 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:43.498 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:43.597 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.597 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.598 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:43.598 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.598 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.598 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:43.598 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:43.697 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.697 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.698 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:43.698 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.698 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.698 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:43.698 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:43.797 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.797 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.797 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:43.798 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:43.798 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:43.798 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:43.798 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:43.798 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 21:28:43.798 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:43.798 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:43.798 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:43.798 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 21:28:43.798 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 21:28:43.798 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:43.798 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:43.798 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:43.801 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:43.801 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 21:28:43.801 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 21:28:43.801 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 21:28:43.801 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 21:28:43.801 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 21:28:43.801 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 21:28:43.801 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 21:28:43.801 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 21:28:43.801 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 21:28:43.801 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 21:28:43.801 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 21:28:43.801 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 21:28:43.801 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 21:28:43.801 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 21:28:43.801 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 21:28:43.801 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 21:28:43.801 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 21:28:43.801 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 21:28:43.801 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 21:28:43.801 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 21:28:43.801 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 21:28:43.801 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 21:28:43.801 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 21:28:43.801 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 21:28:43.801 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 21:28:43.802 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 21:28:43.802 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 21:28:43.802 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 21:28:43.802 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 21:28:43.802 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 21:28:43.802 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 21:28:43.802 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 21:28:43.802 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 21:28:43.802 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 21:28:43.802 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 21:28:43.802 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 21:28:43.802 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 21:28:43.804 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 21:28:43.804 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 21:28:43.804 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 21:28:43.804 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 21:28:43.804 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 21:28:43.804 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 21:28:43.804 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 21:28:43.804 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 21:28:43.804 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 21:28:43.804 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 21:28:43.804 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 21:28:43.805 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 21:28:43.805 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 21:28:43.805 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 21:28:43.805 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 21:28:43.805 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 21:28:43.805 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 21:28:43.805 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 21:28:43.805 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 21:28:43.805 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 21:28:43.805 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 21:28:43.805 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 21:28:43.805 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 21:28:43.805 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 21:28:43.805 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 21:28:43.805 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 21:28:43.805 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 21:28:43.805 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 21:28:43.805 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 21:28:43.805 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 21:28:43.805 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 21:28:43.805 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 21:28:43.805 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 21:28:43.805 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 21:28:43.805 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 21:28:43.805 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 21:28:43.805 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 21:28:43.805 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 21:28:43.805 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 21:28:43.805 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 21:28:43.805 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 21:28:43.805 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 21:28:43.805 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 21:28:43.805 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 21:28:43.805 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 21:28:43.805 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 21:28:43.805 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 21:28:43.805 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 21:28:43.805 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 21:28:43.805 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 21:28:43.805 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 21:28:43.805 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 21:28:43.805 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 21:28:43.805 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 21:28:43.805 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 21:28:43.805 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 21:28:43.805 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 21:28:43.805 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 21:28:43.805 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 21:28:43.805 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 21:28:43.805 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 21:28:43.805 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 21:28:43.805 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 21:28:43.805 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 21:28:43.805 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 21:28:43.805 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 21:28:43.805 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 21:28:43.805 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 21:28:43.805 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 21:28:43.805 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 21:28:43.805 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 21:28:43.805 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 21:28:43.805 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 21:28:43.806 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 21:28:43.806 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 21:28:43.806 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 21:28:43.806 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 21:28:43.806 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 21:28:43.806 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 21:28:43.806 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 21:28:43.806 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 21:28:43.806 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 21:28:43.806 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 21:28:43.806 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 21:28:43.806 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 21:28:43.806 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 21:28:43.806 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 21:28:43.806 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 21:28:43.806 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 21:28:43.806 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 21:28:43.806 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 21:28:43.806 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 21:28:43.806 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 21:28:43.806 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 21:28:43.806 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 21:28:43.806 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 21:28:43.806 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 21:28:43.806 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 21:28:43.806 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 21:28:43.806 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 21:28:43.806 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 21:28:43.806 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 21:28:43.806 asynManager::portThread port=ARV1 callback
RE: Buffer full issue with ADAravis Mark Rivers via Tech-talk
Buffer full issue with ADAravis Katie Matusik via Tech-talk
Re: Buffer full issue with ADAravis Mark Rivers via Tech-talk
Re: Buffer full issue with ADAravis Katie Matusik via Tech-talk
Prev: RE: Buffer full issue with ADAravis Mark Rivers via Tech-talk
Next: RE: Buffer full issue with ADAravis Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
ANJ, 21 Feb 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
