1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: RE: EPICS on windows10 Debian Shell
From: Freddie Akeroyd - UKRI STFC via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 3 Mar 2020 15:19:47 +0000
Would it be possible to do this check at run time rather than compile time - maybe look for a "WSL_DISTRO_NAME" or "WSLENV" environment variable and set a global flag? A non-WSL compiled EPICS program could be run under WSL, this would not be caught by a compile time check. This problem might be fixed in WSL 2 though, so a WSL version check may be required at some point too.
Freddie
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Alfio Rizzo via Tech-talk
Sent: 03 March 2020 09:46
To: tech-talk at aps.anl.gov
Subject: FW: EPICS on windows10 Debian Shell
When I compile epics base on a WSL Debian/Ubunt shell So far I manually commented out (when needed) the _WIN32 macro in the  blockingUDPTransport.cpp file
But a possible clean solution is to create a macro called WSL , checking the kernel version (my kernel is for instance 4.4.0-17763-Microsoft )
ifeq ($(findstring Microsoft,$(shell uname -r)),Microsoft)
CPPFLAGS += -D_WSL_
Endif
Those lines can be put in the RULES_BUILD file of EPICS Base for instance,
Then this macro can be used in the  blockingUDPTransport.cpp file (see attachment)
It could be possible to apply that in the next EPICS base release patch ?
Thanks
Best
Alfio
Sent: Wednesday, October 2, 2019 6:36 AM
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: tech-talk at aps.anl.gov
Hi
The macros are defined the same as any GCC Linux/Unix compiler, I have already checked this before.
See file in attachment
Best
Alfio
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Wednesday, October 2, 2019 2:22 AM
To: Alfio Rizzo <Alfio.Rizzo at esss.se>
Subject: Re: EPICS on windows10 Debian Shell
On 10/1/19 8:55 AM, Alfio Rizzo via Tech-talk wrote:
> As it should be, the OS macro is defined as __linux__ not as _WIN32,
> since the compiler is NOT MinGW or CYGWIN, but GNU as I said before.
> So, then it comes issue I had was this UDP socket biding issue,
> since binding is still handled a la Windows.
> So the problem is in the source file blockingUDPTransport.cpp
> where the macro _WIN32 is not used consistently in my case.
Can you check what macros this compiler pre-defines?
My usual reference doesn't cover this new variation.
https://sourceforge.net/p/predef/wiki/Home/
> cpp -dM /dev/null > wsl_predefined.h
FW: EPICS on windows10 Debian Shell Alfio Rizzo via Tech-talk
Prev: Re: NORD on a char waveform record Mark Rivers via Tech-talk
Next: Re: NORD on a char waveform record Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: FW: EPICS on windows10 Debian Shell Alfio Rizzo via Tech-talk
Next: NORD on a char waveform record Thomas Willemsen - UKRI STFC via Tech-talk
ANJ, 03 Mar 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
