Subject: Re: SIOL field buffer size?
From: Benjamin Franksen via Tech-talk <[email protected]>
Date: Thu, 5 Mar 2020 19:49:02 +0100
Am 05.03.20 um 17:58 schrieb Daykin, Evan via Tech-talk:
> Is it correct that SIOL only holds 40 characters, or is this merely
> a cosmetic trait when the value is pulled from channel access?
The latter. Link fields no longer have this limit (or a much larger
one). But the DBR_STRING request type in CA has a fixed maximum number
of bytes. However, I believe you can nowadays (>= 3.15) use a trailing
'$' in the PV name to make CA use DBR_CHAR with the correct number of
elements.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Re: SIOL field buffer size? Ralph Lange via Tech-talk
SIOL field buffer size? Daykin, Evan via Tech-talk
Prev: write to a single element of an array field Benjamin Franksen via Tech-talk
Next: Re: CA output links not working with PINI=YES? Johnson, Andrew N. via Tech-talk
Prev: SIOL field buffer size? Daykin, Evan via Tech-talk
Next: Re: SIOL field buffer size? Ralph Lange via Tech-talk
