Subject: Re: unable to parse json response when starting Eiger IOC
From: Bruno Martins via Tech-talk <[email protected]>
To: Jong Woo Kim <[email protected]>
Date: Thu, 5 Mar 2020 22:07:53 -0500
Hi Jong,
The following error has been reported at [1]:
Error (511,511) PV: EIG1::TIMEZONE devStringinEnvVar (init_record) Illegal INP parm field
The other errors probably stem from you running ADEiger from master. ADEiger was originally designed to work with Eiger1. Dectris, unfortunately, changed the API in some incompatible ways for the Eiger2. Gary Yendell has been working on a branch [2] to make ADEiger compatible with both Eiger1 and Eiger2 APIs, you might have better luck trying with his branch.
Cheers,
Bruno
On Thu, Mar 5, 2020 at 5:47 PM Jong Woo Kim via Tech-talk <[email protected]> wrote:
Hi ~
I ran into the following errors (bold) when starting Eiger IOC. I found a similar case in the archive. But I don't quite understand.
detector: Eiger2 4M
areaDetector-R3-9
Epics base-7.0.3.1
_________________________________________
#!../../bin/linux-x86_64/eigerDetectorApp
< envPaths
epicsEnvSet("IOC","iocEiger")
epicsEnvSet("TOP","/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC")
epicsEnvSet("ADEIGER","/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC/../..")
epicsEnvSet("SUPPORT","/usr/local/CXLS_SW/EPICS7/synApps_6_1/support")
epicsEnvSet("ASYN","/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/asyn4-37")
epicsEnvSet("AREA_DETECTOR","/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector")
epicsEnvSet("ADSUPPORT","/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADSupport")
epicsEnvSet("ADCORE","/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore")
epicsEnvSet("AUTOSAVE","/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/autosave-R5-10")
epicsEnvSet("BUSY","/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/busy-R1-7-2")
epicsEnvSet("CALC","/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/calc-R3-7-3")
epicsEnvSet("SNCSEQ","/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/seq-2-2-6")
epicsEnvSet("SSCAN","/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/sscan-R2-11-3")
epicsEnvSet("DEVIOCSTATS","/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/iocStats-3-1-16")
epicsEnvSet("EPICS_BASE","/usr/local/CXLS_SW/EPICS7/base-7.0.3.1")
errlogInit(20000)
dbLoadDatabase("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC/dbd/eigerDetectorApp.dbd")
eigerDetectorApp_registerRecordDeviceDriver(pdbbase)
epicsEnvSet("PREFIX", "EIG1:")
epicsEnvSet("PORT",   "EIG")
epicsEnvSet("QSIZE",  "20")
epicsEnvSet("XSIZE",  "2068")
epicsEnvSet("YSIZE",  "2162")
epicsEnvSet("NCHANS", "2048")
epicsEnvSet("CBUFFS", "500")
epicsEnvSet("EIGERIP", "10.212.49.211")
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/db")
epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES", "100000000")
eigerDetectorConfig("EIG", "10.212.49.211", 0, 0)
RestApi::get: [param=description] server returned error code 404
2020/03/05 15:11:30.912 Param[DESCRIPTION]::baseFetch: [param=description] unable to parse json response
2020/03/05 15:11:30.912 Param[DESCRIPTION]::fetch<string>: [param=DESCRIPTION] underlying baseFetch failed
2020/03/05 15:11:30.912 eigerDetector::eigerDetector: Eiger seems to be uninitialized
Initializing... (may take a while)
2020/03/05 15:12:17.810 Param[DESCRIPTION]::baseFetch: [param=description] unable to parse json response
2020/03/05 15:12:17.810 Param[DESCRIPTION]::fetch<string>: [param=DESCRIPTION] underlying baseFetch failed
RestApi::get: [param=link_0] server returned error code 404
2020/03/05 15:12:17.908 Param[LINK_0]::baseFetch: [param=link_0] unable to parse json response
2020/03/05 15:12:17.908 Param[LINK_0]::fetch<int>: [param=LINK_0] underlying baseFetch failed
RestApi::get: [param=link_1] server returned error code 404
2020/03/05 15:12:17.912 Param[LINK_1]::baseFetch: [param=link_1] unable to parse json response
2020/03/05 15:12:17.912 Param[LINK_1]::fetch<int>: [param=LINK_1] underlying baseFetch failed
RestApi::get: [param=link_2] server returned error code 404
2020/03/05 15:12:17.916 Param[LINK_2]::baseFetch: [param=link_2] unable to parse json response
2020/03/05 15:12:17.916 Param[LINK_2]::fetch<int>: [param=LINK_2] underlying baseFetch failed
RestApi::get: [param=link_3] server returned error code 404
2020/03/05 15:12:17.919 Param[LINK_3]::baseFetch: [param=link_3] unable to parse json response
2020/03/05 15:12:17.919 Param[LINK_3]::fetch<int>: [param=LINK_3] underlying baseFetch failed
RestApi::get: [param=builder/dcu_buffer_free] server returned error code 404
2020/03/05 15:12:17.922 Param[DCU_BUF_FREE]::baseFetch: [param=builder/dcu_buffer_free] unable to parse json response
2020/03/05 15:12:17.922 Param[DCU_BUF_FREE]::fetch<double>: [param=DCU_BUF_FREE] underlying baseFetch failed
RestApi::get: [param=buffer_free] server returned error code 404
2020/03/05 15:12:18.019 Param[FW_FREE]::baseFetch: [param=buffer_free] unable to parse json response
2020/03/05 15:12:18.019 Param[FW_FREE]::fetch<int>: [param=FW_FREE] underlying baseFetch failed
RestApi::get: [param=state] server returned error code 404
2020/03/05 15:12:18.023 Param[MONITOR_STATE]::baseFetch: [param=state] unable to parse json response
2020/03/05 15:12:18.023 Param[MONITOR_STATE]::fetch<string>: [param=MONITOR_STATE] underlying baseFetch failed
2020/03/05 15:12:18.701 eigerDetector::eigerDetector: unable to set detector parameters
dbLoadRecords("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC/../../db/eiger.template", "P=EIG1:,R=cam1:,PORT=EIG,ADDR=0,TIMEOUT=1")
Can't set "EIG1:cam1:FWNamePattern.VAL" to "series_$id" Error (512,512)
Error at or before ")" in file "/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC/../../db/eiger.template" line 206
# Debug
#asynSetTraceMask("$(PORT)", 0, 0x11)
# Create a standard arrays plugin
NDStdArraysConfigure("Image1", 5, 0, "EIG", 0, 0)
dbLoadRecords("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/db/NDStdArrays.template", "P=EIG1:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int32,FTVL=LONG,NELEMENTS=4471016, NDARRAY_PORT=EIG")
NDStdArraysConfigure("Image2", 5, 0, "EIG", 1, 0)
dbLoadRecords("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/db/NDStdArrays.template", "P=EIG1:,R=image2:,PORT=Image2,ADDR=0,TIMEOUT=1,TYPE=Int32,FTVL=LONG,NELEMENTS=4471016, NDARRAY_PORT=EIG")
# Load all other plugins using commonPlugins.cmd
< /usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/iocBoot/commonPlugins.cmd
# This is an example file for creating plugins
# It uses the following environment variable macros
# Many of the parameters defined in this file are also in commonPlugins_settings.req so if autosave is being
# use the autosave value will replace the value passed to this file.
# $(PREFIX)      Prefix for all records
# $(PORT)        The port name for the detector.  In autosave.
# $(QSIZE)       The queue size for all plugins.  In autosave.
# $(XSIZE)       The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin and 1-D FFT
#                   profiles in NDPluginFFT.
# $(YSIZE)       The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin
# $(NCHANS)      The maximum number of time series points in the NDPluginStats, NDPluginROIStats, and NDPluginAttribute plugins
# $(CBUFFS)      The maximum number of frames buffered in the NDPluginCircularBuff plugin
# $(MAX_THREADS) The maximum number of threads for plugins which can run in multiple threads. Defaults to 5.
# Create a netCDF file saving plugin
NDFileNetCDFConfigure("FileNetCDF1", 20, 0, "EIG", 0)
dbLoadRecords("NDFileNetCDF.template","P=EIG1:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
# Create a TIFF file saving plugin
NDFileTIFFConfigure("FileTIFF1", 20, 0, "EIG", 0)
dbLoadRecords("NDFileTIFF.template",  "P=EIG1:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
# Create a JPEG file saving plugin
NDFileJPEGConfigure("FileJPEG1", 20, 0, "EIG", 0)
dbLoadRecords("NDFileJPEG.template",  "P=EIG1:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
# Create a NeXus file saving plugin
NDFileNexusConfigure("FileNexus1", 20, 0, "EIG", 0)
dbLoadRecords("NDFileNexus.template", "P=EIG1:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
# Create an HDF5 file saving plugin
NDFileHDF5Configure("FileHDF1", 20, 0, "EIG", 0)
dbLoadRecords("NDFileHDF5.template",  "P=EIG1:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,XMLSIZE=2048,NDARRAY_PORT=EIG")
# Create a Magick file saving plugin
#NDFileMagickConfigure("FileMagick1", $(QSIZE), 0, "$(PORT)", 0)
#dbLoadRecords("NDFileMagick.template","P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
# Create 4 ROI plugins
NDROIConfigure("ROI1", 20, 0, "EIG", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=EIG1:,R=ROI1:,  PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
NDROIConfigure("ROI2", 20, 0, "EIG", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=EIG1:,R=ROI2:,  PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
NDROIConfigure("ROI3", 20, 0, "EIG", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=EIG1:,R=ROI3:,  PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
NDROIConfigure("ROI4", 20, 0, "EIG", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=EIG1:,R=ROI4:,  PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
# Create 8 ROIStat plugins
NDROIStatConfigure("ROISTAT1", 20, 0, "EIG", 0, 8, 0, 0, 0, 0, 5)
dbLoadRecords("NDROIStat.template",   "P=EIG1:,R=ROIStat1:  ,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=EIG1:,R=ROIStat1:1:,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=EIG1:,R=ROIStat1:2:,PORT=ROISTAT1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=EIG1:,R=ROIStat1:3:,PORT=ROISTAT1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=EIG1:,R=ROIStat1:4:,PORT=ROISTAT1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=EIG1:,R=ROIStat1:5:,PORT=ROISTAT1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=EIG1:,R=ROIStat1:6:,PORT=ROISTAT1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=EIG1:,R=ROIStat1:7:,PORT=ROISTAT1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=EIG1:,R=ROIStat1:8:,PORT=ROISTAT1,ADDR=7,TIMEOUT=1,NCHANS=2048")
# Create a processing plugin
NDProcessConfigure("PROC1", 20, 0, "EIG", 0, 0, 0)
dbLoadRecords("NDProcess.template",   "P=EIG1:,R=Proc1:,  PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
# Create a TIFF file plugin to read dark and flatfield images into the processing plugin
NDFileTIFFConfigure("PROC1TIFF", 20, 0, "EIG", 0)
dbLoadRecords("NDFileTIFF.template",  "P=EIG1:,R=Proc1:TIFF:,PORT=PROC1TIFF,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
# Create a scatter plugin
NDScatterConfigure("SCATTER1", 20, 0, "EIG", 0, 0, 0)
dbLoadRecords("NDScatter.template",   "P=EIG1:,R=Scatter1:,  PORT=SCATTER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
# Create a gather plugin with 8 ports
NDGatherConfigure("GATHER1", 20, 0, 8, 0, 0)
dbLoadRecords("NDGather.template",   "P=EIG1:,R=Gather1:, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
dbLoadRecords("NDGatherN.template",   "P=EIG1:,R=Gather1:, N=1, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
dbLoadRecords("NDGatherN.template",   "P=EIG1:,R=Gather1:, N=2, PORT=GATHER1,ADDR=1,TIMEOUT=1,NDARRAY_PORT=EIG")
dbLoadRecords("NDGatherN.template",   "P=EIG1:,R=Gather1:, N=3, PORT=GATHER1,ADDR=2,TIMEOUT=1,NDARRAY_PORT=EIG")
dbLoadRecords("NDGatherN.template",   "P=EIG1:,R=Gather1:, N=4, PORT=GATHER1,ADDR=3,TIMEOUT=1,NDARRAY_PORT=EIG")
dbLoadRecords("NDGatherN.template",   "P=EIG1:,R=Gather1:, N=5, PORT=GATHER1,ADDR=4,TIMEOUT=1,NDARRAY_PORT=EIG")
dbLoadRecords("NDGatherN.template",   "P=EIG1:,R=Gather1:, N=6, PORT=GATHER1,ADDR=5,TIMEOUT=1,NDARRAY_PORT=EIG")
dbLoadRecords("NDGatherN.template",   "P=EIG1:,R=Gather1:, N=7, PORT=GATHER1,ADDR=6,TIMEOUT=1,NDARRAY_PORT=EIG")
dbLoadRecords("NDGatherN.template",   "P=EIG1:,R=Gather1:, N=8, PORT=GATHER1,ADDR=7,TIMEOUT=1,NDARRAY_PORT=EIG")
# Create 5 statistics plugins
NDStatsConfigure("STATS1", 20, 0, "EIG", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=EIG1:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2068,YSIZE=2162,NCHANS=2048,NDARRAY_PORT=EIG")
NDTimeSeriesConfigure("STATS1_TS", 20, 0, "STATS1", 1, 23)
dbLoadRecords("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/db/NDTimeSeries.template",  "P=EIG1:,R=Stats1:TS:, PORT=STATS1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS2", 20, 0, "ROI1",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=EIG1:,R=Stats2:,  PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2068,YSIZE=2162,NCHANS=2048,NDARRAY_PORT=EIG")
NDTimeSeriesConfigure("STATS2_TS", 20, 0, "STATS2", 1, 23)
dbLoadRecords("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/db/NDTimeSeries.template",  "P=EIG1:,R=Stats2:TS:, PORT=STATS2_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS2,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS3", 20, 0, "ROI2",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=EIG1:,R=Stats3:,  PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2068,YSIZE=2162,NCHANS=2048,NDARRAY_PORT=EIG")
NDTimeSeriesConfigure("STATS3_TS", 20, 0, "STATS3", 1, 23)
dbLoadRecords("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/db/NDTimeSeries.template",  "P=EIG1:,R=Stats3:TS:, PORT=STATS3_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS3,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS4", 20, 0, "ROI3",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=EIG1:,R=Stats4:,  PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2068,YSIZE=2162,NCHANS=2048,NDARRAY_PORT=EIG")
NDTimeSeriesConfigure("STATS4_TS", 20, 0, "STATS4", 1, 23)
dbLoadRecords("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/db/NDTimeSeries.template",  "P=EIG1:,R=Stats4:TS:, PORT=STATS4_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS4,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS5", 20, 0, "ROI4",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=EIG1:,R=Stats5:,  PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2068,YSIZE=2162,NCHANS=2048,NDARRAY_PORT=EIG")
NDTimeSeriesConfigure("STATS5_TS", 20, 0, "STATS5", 1, 23)
dbLoadRecords("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/db/NDTimeSeries.template",  "P=EIG1:,R=Stats5:TS:, PORT=STATS5_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS5,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
# Create a transform plugin
NDTransformConfigure("TRANS1", 20, 0, "EIG", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDTransform.template", "P=EIG1:,R=Trans1:,  PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
# Create an overlay plugin with 8 overlays
NDOverlayConfigure("OVER1", 20, 0, "EIG", 0, 8, 0, 0, 0, 0, 5)
dbLoadRecords("NDOverlay.template", "P=EIG1:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
dbLoadRecords("NDOverlayN.template","P=EIG1:,R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=EIG1:ROI1:MinX_RBV,YPOS=EIG1:ROI1:MinY_RBV,XSIZE=EIG1:ROI1:SizeX_RBV,YSIZE=EIG1:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=EIG1:,R=Over1:2:,NAME=ROI2,   SHAPE=1,O=Over1:,XPOS=EIG1:ROI2:MinX_RBV,YPOS=EIG1:ROI2:MinY_RBV,XSIZE=EIG1:ROI2:SizeX_RBV,YSIZE=EIG1:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=EIG1:,R=Over1:3:,NAME=ROI3,   SHAPE=1,O=Over1:,XPOS=EIG1:ROI3:MinX_RBV,YPOS=EIG1:ROI3:MinY_RBV,XSIZE=EIG1:ROI3:SizeX_RBV,YSIZE=EIG1:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=EIG1:,R=Over1:4:,NAME=ROI4,   SHAPE=1,O=Over1:,XPOS=EIG1:ROI4:MinX_RBV,YPOS=EIG1:ROI4:MinY_RBV,XSIZE=EIG1:ROI4:SizeX_RBV,YSIZE=EIG1:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=EIG1:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=4,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=EIG1:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=5,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=EIG1:,R=Over1:7:,NAME=Box1,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=6,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=EIG1:,R=Over1:8:,NAME=Box2,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=7,TIMEOUT=1")
# Create 2 color conversion plugins
NDColorConvertConfigure("CC1", 20, 0, "EIG", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDColorConvert.template", "P=EIG1:,R=CC1:,  PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
NDColorConvertConfigure("CC2", 20, 0, "EIG", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDColorConvert.template", "P=EIG1:,R=CC2:,  PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
# Create a circular buffer plugin
NDCircularBuffConfigure("CB1", 20, 0, "EIG", 0, 500, 0)
dbLoadRecords("NDCircularBuff.template", "P=EIG1:,R=CB1:,  PORT=CB1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=EIG")
# Create an NDAttribute plugin with 8 attributes
NDAttrConfigure("ATTR1", 20, 0, "EIG", 0, 8, 0, 0, 0)
dbLoadRecords("NDAttribute.template",  "P=EIG1:,R=Attr1:,    PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048,NDARRAY_PORT=EIG")
dbLoadRecords("NDAttributeN.template", "P=EIG1:,R=Attr1:1:,  PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=EIG1:,R=Attr1:2:,  PORT=ATTR1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=EIG1:,R=Attr1:3:,  PORT=ATTR1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=EIG1:,R=Attr1:4:,  PORT=ATTR1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=EIG1:,R=Attr1:5:,  PORT=ATTR1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=EIG1:,R=Attr1:6:,  PORT=ATTR1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=EIG1:,R=Attr1:7:,  PORT=ATTR1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=EIG1:,R=Attr1:8:,  PORT=ATTR1,ADDR=7,TIMEOUT=1,NCHANS=2048")
NDTimeSeriesConfigure("ATTR1_TS", 20, 0, "ATTR1", 1, 8)
dbLoadRecords("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/db/NDTimeSeries.template",  "P=EIG1:,R=Attr1:TS:, PORT=ATTR1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ATTR1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
# Create an FFT plugin
NDFFTConfigure("FFT1", 20, 0, "EIG", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDFFT.template", "P=EIG1:, R=FFT1:, PORT=FFT1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=EIG, NAME=FFT1, NCHANS=2068")
# Create 2 Codec plugins
NDCodecConfigure("CODEC1", 20, 0, "EIG", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDCodec.template", "P=EIG1:, R=Codec1:, PORT=CODEC1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=EIG")
NDCodecConfigure("CODEC2", 20, 0, "EIG", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDCodec.template", "P=EIG1:, R=Codec2:, PORT=CODEC2, ADDR=0, TIMEOUT=1, NDARRAY_PORT=EIG")
set_requestfile_path("./")
set_requestfile_path("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/ADApp/Db")
set_requestfile_path("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADCore/iocBoot")
set_savefile_path("./autosave")
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
save_restoreSet_status_prefix("EIG1:")
dbLoadRecords("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/autosave-R5-10/asApp/Db/save_restoreStatus.db", "P=EIG1:")
# Optional: load NDPluginPva plugin
#NDPvaConfigure("PVA1", $(QSIZE), 0, "$(PORT)", 0, $(PREFIX)Pva1:Image, 0, 0, 0)
#dbLoadRecords("NDPva.template",  "P=$(PREFIX),R=Pva1:, PORT=PVA1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
# Must start PVA server if this is enabled
#startPVAServer
# Optional: load ffmpegServer plugin
#ffmpegServerConfigure(8081)
#ffmpegStreamConfigure("FfmStream1", 2, 0, "$(PORT)", 0, -1, 0)
#dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegStream.template", "P=$(PREFIX),R=ffmstream1:,PORT=FfmStream1,NDARRAY_PORT=$(PORT)")
#ffmpegFileConfigure("FfmFile1", 16, 0, "$(PORT)", 0, -1, 0)
#dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegFile.template", "P=$(PREFIX),R=ffmfile1:,PORT=FfmFile1,NDARRAY_PORT=$(PORT)")
# Optional: load NDPluginEdge plugin
#NDEdgeConfigure("EDGE1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0)
#dbLoadRecords("$(ADPLUGINEDGE)/db/NDEdge.template",  "P=$(PREFIX),R=Edge1:, PORT=EDGE1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADPLUGINEDGE)/edgeApp/Db")
# Optional: load NDPluginCV plugin
#NDCVConfigure("CV1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
#dbLoadRecords("$(ADCOMPVISION)/db/NDCV.template",  "P=$(PREFIX),R=CV1:, PORT=CV1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADCOMPVISION)/adcvApp/Db")
# Optional: load NDPluginBar plugin
#NDBarConfigure("BAR1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
#dbLoadRecords("$(ADPLUGINBAR)/db/NDBar.template",  "P=$(PREFIX),R=Bar1:, PORT=BAR1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADPLUGINBAR)/barApp/Db")
# Optional: load scan records
#dbLoadRecords("$(SSCAN)/sscanApp/Db/scan.db", "P=$(PREFIX),MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10")
set_requestfile_path("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/sscan-R2-11-3/sscanApp/Db")
# Optional: load sseq record for acquisition sequence
#dbLoadRecords("$(CALC)/calcApp/Db/sseqRecord.db", "P=$(PREFIX), S=AcquireSequence")
set_requestfile_path("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/calc-R3-7-3/calcApp/Db")
# Optional: load devIocStats records (requires DEVIOCSTATS module)
dbLoadRecords("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/iocStats-3-1-16/db/iocAdminSoft.db", "IOC=EIG1:")
# Optional: load alive record (requires ALIVE module)
#dbLoadRecords("$(ALIVE)/aliveApp/Db/alive.db", "P=$(PREFIX),RHOST=192.168.1.254")
# Set the callback queue size to 5000, up from default of 2000 in base.
# This can be needed to avoid errors "callbackRequest: cbLow ring buffer full".
callbackSetQueueSize(5000)
set_requestfile_path("/usr/local/CXLS_SW/EPICS7/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC/../../eigerApp/Db")
iocInit()
Starting iocInit
## EPICS R7.0.3.1
## EPICS Base built Mar  3 2020
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
RestApi::get: [param=detector_readout_time] server returned error code 404
2020/03/05 15:12:19.177 Param[EIG_DCD_detector_readout_time]::baseFetch: [param=detector_readout_time] unable to parse json response
2020/03/05 15:12:19.177 Param[EIG_DCD_detector_readout_time]::fetch<double>: [param=EIG_DCD_detector_readout_time] underlying baseFetch failed
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 43355,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
2020-03-05T15:12:19.834 Using dynamically assigned TCP port 33885.
# Avoid deluge of messages when debugging
#dbpf $(PREFIX)cam1:PoolUsedMem.SCAN Passive
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30, "P=EIG1:")
epics> auto_settings.sav: 2335 of 2335 PV's connected
epics>
unable to parse json response when starting Eiger IOC Jong Woo Kim via Tech-talk
Prev: RE: write to a single element of an array field Di Wang via Tech-talk
Next: Re: Problem during compilation of IOC with custom ADPlugin Gofron, Kazimierz via Tech-talk
Prev: unable to parse json response when starting Eiger IOC Jong Woo Kim via Tech-talk
Next: New ADCompVision release, ADUVC UVC camera driver Wlodek, Jakub via Tech-talk
