Subject: Re: [EXTERNAL] vxW shell related
From: "Hartman, Steven M. via Tech-talk" <[email protected]>
To: Stefen Paul <[email protected]>
Date: Wed, 11 Mar 2020 15:38:40 +0000
> On Mar 11, 2020, at 9:54 AM, Stefen Paul via Tech-talk <[email protected]> wrote:
> I am using vxWorks on MVME CPU boards. I have two queries related to the same :
You didn’t say which version of VxWorks you are using (and my experience may be out of date) but . . .
> I want the shell to be accessible only through Telnet login and not through the default serial port terminal ... can it be done ?
I don’t think so. Traditionally VxWorks has required all targets to have a serial port terminal.
> 2) I want to disable the feature of resetting the CPU by Ctrl+X  key combination .... how to do it ?
You can change the key combination with tyMonitorTrapSet( ) or disable the feature by setting OPT_MON_TRAP appropriately.
Steven Hartman
[email protected]
Re: [EXTERNAL] vxW shell related Johnson, Andrew N. via Tech-talk
vxW shell related Stefen Paul via Tech-talk
Prev: Re: StreamDevice Raw converter Henrique Silva via Tech-talk
Next: Re: [EXTERNAL] vxW shell related Johnson, Andrew N. via Tech-talk
Prev: vxW shell related Stefen Paul via Tech-talk
