Thank you, Kasemir,
I use CSS version 3.2, which is pretty old.
However, currently we have not plan to upgrade.
Is it just impossible to do what I want in such old version of CSS?
Or are there something I can try/work around?
Thanks.
寄件者: Kasemir, Kay <kasemirk at ornl.gov>
寄件日期: 2020年3月16日 下午 08:28
收件者: tech-talk at aps.anl.gov; Chiang, Liang-Chih [江良志]
主旨: Re: How can I apply some transformation to the X/Y axis coordinates of CSS Intensity Graph widget?
(Note that the "Intensity Graph" widget has been renamed into "Image Widget", but it'll map that automatically when you open existing *.opi files)
-Kay
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Chiang, Liang-Chih [江良志] via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, March 16, 2020 4:15 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] How can I apply some transformation to the X/Y axis coordinates of CSS Intensity Graph widget?
I use CSS Intensity Graph to show the 2D image data from areaDetector module.
https://www.dropbox.com/s/du09abigpjebybw/css_intensity_graph.png?dl=0
The coordinates of X axis and Y axis are from 0 to 491.
How can I apply some kind of transformation to the coordiate?
For example, Xnew = (X - 250) * 0.05,
the values of Xnew will be from -8.2852 to 6.8376.
ps I have few experience on areaDetector module.
Best regards.
LiangChih Chiang
email:
chiang.lc at nsrrc.org.tw
Beamline Group
National Synchrotron Radiation Research Center (NSRRC)
- How can I apply some transformation to the X/Y axis coordinates of CSS Intensity Graph widget? Chiang, Liang-Chih [江良志] via Tech-talk
- Re: How can I apply some transformation to the X/Y axis coordinates of CSS Intensity Graph widget? Kasemir, Kay via Tech-talk
Re: How can I apply some transformation to the X/Y axis coordinates of CSS Intensity Graph widget? D. Peter Siddons via Tech-talk
<2020>
2025
<2020>
2025
ANJ, 16 Mar 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
