1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: Newport DL325
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Igor Kriznar <Igor.Kriznar at partner.kit.edu>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Tue, 31 Mar 2020 18:01:28 +0000
Hi Igor,
It looks like they are only supporting the DL Single-Axis Motion Controller for those stages.
The User Manual documents the command syntax: https://www.newport.com/mam/celum/celum_assets/resources/DL_-_Controller_Users_Manual.pdf?1
The command syntax is very similar to the Newport AG_CONEX controllers, for which there is an EPICS driver.
https://github.com/epics-motor/motorNewport/blob/master/newportApp/src/AG_CONEX.cpp
You may be able to use the AG_CONEX driver, or you may have to write a new driver starting with that one but modifying the commands and syntax a bit.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Igor Kriznar via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, March 31, 2020 8:27 AM
To: tech-talk at aps.anl.gov
Subject: Newport DL325
is motor record working with Newport DL325 (a Delay Line Stage) with DL
Controller?
Thanks!
Best regards, Igor
Newport DL325 Igor Kriznar via Tech-talk
Prev: EPICS7 roller-coaster Rolf Keitel via Tech-talk
Next: Re: EPICS7 roller-coaster Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Prev: Newport DL325 Igor Kriznar via Tech-talk
Next: Re: Newport DL325 Mark Rivers via Tech-talk
ANJ, 01 Apr 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
