Subject: NTNDArray array filter does not work on value
From: Marty Kraimer via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 1 Apr 2020 09:10:53 -0400
In thread  "EPICS7 roller-coaster" Mark Rivers asked
On 3/31/20 3:11 PM, Mark Rivers via Tech-talk wrote
Here is a little feedback, actually something to add to a wish list.
pvget and pvmonitor really need a way to limit the output, similar to the -# <count> flag in caget and camonitor.  Since pvget could be returning multiple array fields the simplest implementation would be to use this limit for the number of values to print on each of them.
I often want to do pvget or pvmonitor on an NTNDArray structure.  But I don't want to see all 2+ million values of the image, I just want to see a few values and the rest of the structure.
Since areaDetector NTNDArray is implemented via pvDatabaseCPP, I think this is an issue for pvDatabaseCPP.
pvDatabaseCPP has support for an array filter, which currently works on any scalarArray field.
It does NOT work on a union field that is set to be a scalarArray.
I am going to see how to make it work for a union field that is set to be a scalarArray.
Let me give some examples on using the array filter:
The following assumes that exampleCPP/database is used to start an IOC.
mrk> pvinfo PVRdoubleArray
PVRdoubleArray
Server: 10.0.0.11:5075
Type:
    epics:nt/NTScalarArray:1.0
        double[] value
        alarm_t alarm
            int severity
            int status
            string message
        time_t timeStamp
            long secondsPastEpoch
            int nanoseconds
            int userTag
mrk> pvget -r value PVRdoubleArray
PVRdoubleArray []
mrk> pvput PVRdoubleArray [1,2,3,4,5,6,7,8,9,10]
Old : <undefined>              []
New : 2020-04-01 08:59:47.905  [1,2,3,4,5,6,7,8,9,10]
mrk> pvget -r 'value[array=0:2]' PVRdoubleArray
PVRdoubleArray [1,2,3]
mrk> pvput -r 'value[array=0:2]' PVRdoubleArray [100,200,300]
Old : [1,2,3]
New : [100,200,300]
But if you try to use an array filter on a union field it does not work
mrk> pvinfo PVRvariantUnion
PVRvariantUnion
Type:
    epics:nt/NTUnion:1.0
        any value
        time_t timeStamp
            int nanoseconds
            int userTag
mrk> pvput -r 'value[array=0:2]' PVRvariantUnion [100,200,300]
Old : structure
    any value
        (none)
value : Error not a scalar array field
Error: Not a scalar array field
New : structure
    any value
        (none)
RE: NTNDArray array filter does not work on value Mark Rivers via Tech-talk
EPICS7 roller-coaster Rolf Keitel via Tech-talk
Re: EPICS7 roller-coaster Michael Davidsaver via Tech-talk
Re: EPICS7 roller-coaster Mark Rivers via Tech-talk
Prev: Re: Newport DL325 Mark Rivers via Tech-talk
Next: RE: NTNDArray array filter does not work on value Mark Rivers via Tech-talk
Prev: Re: EPICS7 roller-coaster Michael Davidsaver via Tech-talk
