Subject: Re: Setting an array to zero length
From: Ben Franksen via Tech-talk <[email protected]>
To: "Rogers, Will (DLSLtd,RAL,LSCI)" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 3 Apr 2020 15:33:38 +0200
Am 03.04.20 um 15:04 schrieb Ben Franksen via Tech-talk:
> Am 03.04.20 um 12:43 schrieb Rogers, Will (DLSLtd, RAL, LSCI) via Tech-talk:
>> I suspect that this may not be a simple question, but:
>> *   If I create a waveform WAVE with a soft IOC of length 10, it has
>> WAVE.NELM as 10 and WAVE.NORD as 0 *   If I caput 5 elements to it
>> (e.g. with Cothread) it has WAVE.NELM as 10 and WAVE.NORD as 5
>> Is there a way to restore it to its uninitialised state with
>> WAVE.NORD as 0? How general could this be for different record
>> types?
> The first thing I would try is:
>   caput -a WAVE 0
That gives me
Error from put operation: Invalid element count requested
Apparently this is the ECA_BADCOUNT error that comes from the CA client
library. So this is broken by design. You may have more luck with a
different CA client library (one of the Java versions?).
Cheers
Ben
...it is impossible to speak of a depoliticized economy as the liberals
do, or of a separation between economic exploitation and political
oppression as the Marxists articulate. The basic distinction, rather, is
between power and creativity...
             -- Jonathan Nitzan and Shimshon Bichler: Capital as Power
Attachment: signature.asc
Description: OpenPGP digital signature
Setting an array to zero length Rogers, Will (DLSLtd, RAL, LSCI) via Tech-talk
Re: Setting an array to zero length Ben Franksen via Tech-talk
Prev: Re: Setting an array to zero length Ben Franksen via Tech-talk
Next: Re: Setting an array to zero length Ralph Lange via Tech-talk
