Subject: Re: 'System.dbd' in EPICS base
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Mogamad Amien Crombie <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 6 Apr 2020 15:28:14 +0000
Hi Amien,
On Apr 4, 2020, at 2:20 AM, Mogamad Amien Crombie via Tech-talk <[email protected]> wrote:
Sometimes we have to do some 'system' calls from inside EPICS shell.
As far as I know, the normal way is to add the 'system.dbd' to the IOC's /src/app Makefile.
Is it possible to have this in oun Epics Base so that it is enabled for all our IOC's ?  The 'ReadLine' (shell history etc) is done inside the base .
You can of course make any changes you like to the code in your Base installation before you build it. We don’t have a build configuration flag that adds system.dbd to all IOCs, so the easiest way for you to achieve this would be to edit the file Base-3.15.x/src/std/softIoc/base.dbd or Base-7.0/modules/database/src/std/softIoc/base.dbd and add a line
include “system.dbd”
to the end of that file. Personally I would handle that requirement slightly differently though – our operational IOCs all build with a locally developed support module that provides common standard facilities, and I would put that kind of setting into our iocStdSoft.dbd file instead of modifying base.dbd
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
'System.dbd' in EPICS base Mogamad Amien Crombie via Tech-talk
Prev: Re: Contributing a new how-to to the EPICS web site Konrad, Martin via Tech-talk
Next: Re: Contributing a new how-to to the EPICS web site Mark Rivers via Tech-talk
Prev: 'System.dbd' in EPICS base Mogamad Amien Crombie via Tech-talk
Next: test automation tools on Control System studio screens Hinko Kocevar via Tech-talk
