Subject: StreamDevice and negative hex values
Date: Thu, 16 Apr 2020 14:26:47 -0400
I have a question about conversion of hex input strings in StreamDevice.
If I have in statements in StreamDevice protocols that, when reading the input strings "FFFF" and "8000" using the string "%4X" conversion, results in the value 65535 and 32768 (at least when using a longin record).  Given that the end result IS a long integer, this makes some sense.
However, from the point of view of the device that produces these strings, they are 2-byte signed values, so they represent the values -1 and -32678.
Is there some way to get StreamDevice to interpret these as negative values?
I see that later versions of the StreamDevice doco includes this statement regarding the Standard LONG Converters:
    "With the - negative octal and hexadecimal values are accepted."
But what does that mean?  I tried changing the protocol to -4X rather than 4X but it made no difference.
How would the '-' option be used, and under what circumstances would it result in a negative long integer value that (without the "-" prefix) would have been a positive value?
NOTE:  For now I am just using a calc record to handle the 2-byte 2's complement format used by the device.
Mark Davis
NSCL/FRIB Control Systems Software Engineer
[email protected]
Prev: Alarm Reports (JSP web package) John Dobbins via Tech-talk
Next: How to use SRQ from device in StreamDevice. Noboru Yamamoto via Tech-talk
