> Yes that said Multiple.
That is what I suspected. So the problem is the logic in ADGenICam. Even though that camera does not support AcquisitionMode=MultiFrame when ADGenICam reads back the AcquisitionMode feature it translates the enum to ADImageModeMultiple.
I have made a change in ADGenICam that should fix the problem. You can either try the master branch of ADGenICam or apply this patch.
diff --git a/GenICamApp/src/GenICamFeature.cpp b/GenICamApp/src/GenICamFeature.cpp
index 85d57a9..0ab35d5 100644
--- a/GenICamApp/src/GenICamFeature.cpp
+++ b/GenICamApp/src/GenICamFeature.cpp
@@ -491,7 +491,12 @@ int GenICamFeature::convertEnum(epicsInt32 inputValue, GCConvertDirection_t dire
outputValue = mSet->mAcquisitionModeSingleFrame;
break;
case ADImageMultiple:
- outputValue = mSet->mAcquisitionModeMultiFrame;
+ // Some cameras, e.g. JAI don't support MultiFrame so we convert to Continuous
+ if (mSet->mAcquisitionModeMultiFrame != -1) {
+ outputValue = mSet->mAcquisitionModeMultiFrame;
+ } else {
+ outputValue = mSet->mAcquisitionModeContinuous;
break;
case ADImageContinuous:
@@ -503,7 +508,8 @@ int GenICamFeature::convertEnum(epicsInt32 inputValue, GCConvertDirection_t dire
GenICamFeatureSet::GenICamFeatureSet (asynPortDriver *portDriver, asynUser *user)
-: mPortDriver(portDriver), mUser(user), mFeatureMap(), mAsynMap()
+: mPortDriver(portDriver), mUser(user), mFeatureMap(), mAsynMap(),
+ mAcquisitionModeSingleFrame(-1), mAcquisitionModeMultiFrame(-1), mAcquisitionModeContinuous(-1)
void GenICamFeatureSet::insert(GenICamFeature *pFeature, string const & name)
-----Original Message-----
From: Steve Kinder - UKRI STFC <steve.kinder at stfc.ac.uk>
Sent: Tuesday, April 21, 2020 9:28 AM
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Subject: Re: ADAravis JAI camera stops
$ caget EBT-TST-T20-DIA-CAM-01:CAM:ImageMode_RBV
EBT-TST-T20-DIA-CAM-01:CAM:ImageMode_RBV Multiple $ caput EBT-TST-T20-DIA-CAM-01:CAM:ImageMode Continuous Old : EBT-TST-T20-DIA-CAM-01:CAM:ImageMode Multiple New : EBT-TST-T20-DIA-CAM-01:CAM:ImageMode Continuous $ caget EBT-TST-T20-DIA-CAM-01:CAM:ImageMode_RBV
Still stops after 100 images.
Steve
Sent: 21 April 2020 14:27:37
To: Kinder, Steve (STFC,DL,TECH)
Cc: EPICS tech-talk
Subject: RE: ADAravis JAI camera stops
Your template file shows that the JAI cameras do not support MultipleFrame for the GenICam AcquisitionMode feature.
If you type:
do you see "Multiple"?
If so then the problem is that the logic in ADGenICam does not correctly handle the case where MultipleFrame is not supported, because I was not aware that some cameras did not support that. That logic is going to need to be improved to handle these cameras.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Steve Kinder - UKRI STFC via Tech-talk
Sent: Tuesday, April 21, 2020 8:12 AM
To: Steve Kinder - UKRI STFC <steve.kinder at stfc.ac.uk>; tech-talk at aps.anl.gov
A few debug prints lead me to think the problem is associated with ADAravis:run() believing the camera is in image mode, ADImageMultiple, and then stopping after NumImages have been collected. However I believe it is set up in Continuous mode. Perhaps it is down to the generated template for my JAI cameras and the logic in the run method? Please see below:
$ caget EBT-TST-T20-DIA-CAM-01:CAM:GC_AcquisitionMode
EBT-TST-T20-DIA-CAM-01:CAM:GC_AcquisitionMode Continuous ]$ caget EBT-TST-T20-DIA-CAM-01:CAM:GC_AcquisitionMode_RBV
EBT-TST-T20-DIA-CAM-01:CAM:GC_AcquisitionMode_RBV Continuous $ caget EBT-TST-T20-DIA-CAM-01:CAM:NumImages
EBT-TST-T20-DIA-CAM-01:CAM:NumImages 100
record(mbbi, "$(P)$(R)GC_AcquisitionMode_RBV") {
field(DTYP, "asynInt32")
field(INP, "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))GC_E_AcquisitionMode")
field(ZRST, "Continuous")
field(ZRVL, "0")
field(ONST, "SingleFrame")
field(ONVL, "1")
field(TWST, "SingleFrameReado")
field(TWVL, "0x10006")
field(SCAN, "I/O Intr")
field(DISA, "0")
record(mbbo, "$(P)$(R)GC_AcquisitionMode") {
field(OUT, "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))GC_E_AcquisitionMode")
field(DOL, "0")
field(ZRVL, "0")
field(ONVL, "1")
field(DISA, "0")
The run method sees imageMode as 1 and stops the camera after 100 images.
Steve
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Steve Kinder - UKRI STFC via Tech-talk <tech-talk at aps.anl.gov>
Sent: 21 April 2020 10:38:50
To: tech-talk at aps.anl.gov
Subject: ADAravis JAI camera stops
I am moving a camera IOC from aravisGigE to ADAravis. Things mostly seem to be working so far. I have 1 * AVT G-235B and 2 * JAI BM141GE on a test IOC. I see no problem with the former so far. I'm seeing slightly confusing hangs with the JAIs though. One of these is being triggered at 10 Hz. It seems to just stop after the ARFramesCompleted PV gets to 100? This also happens when I turn the trigger off and free run at 30Hz. I don't get any messages/errors on the IOC console. If I stop the camera and start again the same thing keeps happening. ADAravis and ADGenICam both 1-2. Any thoughts or advice would be appreciated.
Thanks
Steve
- Re: ADAravis JAI camera stops Steve Kinder - UKRI STFC via Tech-talk
- ADAravis JAI camera stops Steve Kinder - UKRI STFC via Tech-talk
- RE: ADAravis JAI camera stops Mark Rivers via Tech-talk
<2020>
<2020>
