Subject: Re: Tips for doing conditional logic in EPICS records
To: John Priller <[email protected]>, "[email protected]" <[email protected]>, Mark Davis <[email protected]>
Date: Mon, 27 Apr 2020 15:59:39 +0000
Hi Mark,
I think you can do what you want with a single transform record.  I was trying to see how to do that when I realized I don't understand your logic.
I the first line in your for loop you conditionally set flag=1.  However,  the only place you use the flag in the loop is in line 2 which will not be executed if flag was set in line 1.  Then flag is unconditionally set back to 0 in line 4.   I don't understand how etting flag=1 in line 1 do anything useful?  I'm probably missing something.
From: Tech-talk <[email protected]> on behalf of Mark Davis via Tech-talk <[email protected]>
Sent: Monday, April 27, 2020 10:05 AM
To: [email protected]; John Priller
Subject: Tips for doing conditional logic in EPICS records
Hi all,
I am looking for some tips on the best way to implement logic such as
the following using EPICS records:
flag = 1;
for (each new set of readings)  {
     if (readbackA == fixedVal1)   flag = 1;  else
     if (flag == 1)  setVal = readbackB;  else
     if (readBackC == fixedVal2)  setVal = readbackD;
     flag = 0;
For the initial setting I figured simply a record that includes the
initial value in the VAL field (and PINI set to "Yes"?).
The for "loop" would be simply an FLNK in the record (or last in a
sequence of records) that gets the new readings, triggering the
processing of the the record that handles the 1st if condition (in this
case, I have one record that gets them all at once).
At that point how to best to proceed is not obvious to me, and there are
probably  lots of possibilities (A sequence of calcout or scalcout
records?  Maybe a transform record?)
Suggestions?
Mark Davis
NSCL/FRIB Control Systems Software Engineer
[email protected]
Re: Tips for doing conditional logic in EPICS records Davis, Mark via Tech-talk
Tips for doing conditional logic in EPICS records Mark Davis via Tech-talk
Prev: Re: Adding new record to EPICS 7 IOC with pvDatabase Marty Kraimer via Tech-talk
Next: Re: Tips for doing conditional logic in EPICS records Mooney, Tim M. via Tech-talk
Prev: Re: [EXTERNAL] Tips for doing conditional logic in EPICS records Kasemir, Kay via Tech-talk
Next: Re: Tips for doing conditional logic in EPICS records Davis, Mark via Tech-talk
