One way to do conditional execution in an EPICS database is by using the SELM and SELN fields of a seq record. Set SELM to "Specified", and write a number to the SELN field. If you want more than one of several things to happen, you can write "Mask" to SELM,
and write a bitmap value to SELN, specifying which things to do.
+1
The combination of a calcout record (evaluating conditions) writing to a seq record in "Mask" mode (executing actions) is extremely powerful. As actions can include delays and changing the calcout's fields, that setup is good enough for a small state machine. (You will also win any district level obfuscation contest.)
Cheers, ~Ralph
- Re: Tips for doing conditional logic in EPICS records Mark Davis via Tech-talk
- Tips for doing conditional logic in EPICS records Mark Davis via Tech-talk
- Re: Tips for doing conditional logic in EPICS records Mooney, Tim M. via Tech-talk
Re: Adding new record to EPICS 7 IOC with pvDatabase Joao Paulo Martins via Tech-talk
<2020>
2025
<2020>
2025
ANJ, 30 Apr 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
