Greetings
I haven't used EPICS for a while but am helping out a local facility get a new system up and running using EPICS. They want to use The Advanced Control System (ACS) motor control. The controller is the SPI-8 8-channel Indexer/Controller Module. Is this supported by the Motor record? There are a couple of motor drivers for ACS distributed with the EPICS motor record; I assume if one is applicable it is the motorAcsTech80. Will this work with the SPI-8 Indexer Module from ACS? The last revision date on the manual they gave me is 2008 so they may be using an old controller. Thanks for any help Mark Mark Vigder TVB Associates
ANJ, 30 Apr 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
