1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Announcing epics-base 7.0.3.1 on conda-forge
From: Benjamin Bertrand via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 7 May 2020 21:31:03 +0000
Hello,
I'd like to announce the availability of epics-base 7.0.3.1 on conda-forge: https://github.com/conda-forge/epics-base-feedstock
The package is available on Linux, macOS and Windows.
If you only want to get EPICS Base on your machine, conda is a fast way to achieve that.
For those interested, I wrote a blog post with some details:
https://beenje.github.io/blog/posts/using-epics-base-with-conda-on-linux-macos-and-windows/
I knew there were several epics-base conda package around (PSI, pvaPy...), but discovered only recently that epics-base 3.15 was on conda-forge.
It has now been updated to the latest EPICS release. I hope this message will make this information more widespread.
A huge thanks to all the people who contributed to that conda recipe!
Best Regards,
Benjamin
Prev: Re: EPICS DB file automation for PLC from spreadsheet Lucas Russo via Tech-talk
Next: Re: EPICS DB file automation for PLC from spreadsheet Shen, Guobao via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Carsten Winkler via Tech-talk
Next: controlsystemstudio.org down Peter Milne via Tech-talk
ANJ, 08 May 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
