Subject: Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug"
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Carsten Winkler <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 18 May 2020 20:23:16 -0700
The same issue from back in 2004.
https://epics.anl.gov/tech-talk/2004/msg00743.php
FYI. your code might call GetModuleHandleEx() with
GET_MODULE_HANDLE_EX_FLAG_FROM_ADDRESS giving eg. the
address of ca_context_create() and
GET_MODULE_HANDLE_EX_FLAG_PIN to ensure prevent ca.dll
from ever being unloaded.
https://docs.microsoft.com/en-us/windows/win32/api/libloaderapi/nf-libloaderapi-getmodulehandleexa
On 5/18/20 11:24 AM, Carsten Winkler wrote:
> Hi Andrew,
> I am afraid that I have unknowingly used a glitch in the past. My simple example don't work for any EPICS Base version. But up to EPICS Base 3.14.12.8 I could unload the library by using the destructor function of a static object in my interface library.
> After compiling CA Lab with EPICS Base 7, LabVIEW now freezes completely when you close a VI with CA Lab modules. This problem is new and very critical.
> Am 18.05.2020 um 19:56 schrieb Johnson, Andrew N.:
>> Hi Carsten,
>> I’m not aware of anything that has actually been added to libCom or libca recently to prevent a completely shutdown; are you saying that you used to be able to unload the CA library and you can’t now? I don’t believe this has ever been possible (which is probably what Michael is also going by), but I might be wrong – please let us know what version of Base you were using if and when you could do that.
>> If it’s your requirement that has changed we would be happy to advise someone how to work out what needs to be modified to allow the complete unloading that you’re looking for, but I can’t promise that we’ll have core developer effort available to do the actual investigation and any development needed (we all manage our own time and have our own priorities controlled by our employers, so I can’t speak for the others).
>> - Andrew
>> On May 18, 2020, at 12:21 PM, Carsten Winkler via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
>>> thank you for your answer. This are bad news for our community. Many users are waiting for an EPICS Base upgrade for the Open Source software CaLab (interface beween LabVIEW and EPICS) <http://hz-b.de/calab>.
>>> Best reganrds
>>> Carsten
>>> Am 18.05.2020 um 18:27 schrieb Michael Davidsaver:
>>>> libca and especially libCom can't be completely shutdown, and therefore
>>>> can't be safely unloaded.
>>>> On 5/18/20 8:34 AM, Carsten Winkler via Tech-talk wrote:
>>>>> Hi,
>>>>> for a project I need to load and unload the Channel Access context in a
>>>>> shared library. Loading is no problem but unloading. It always fails
>>>>> during ca_context_destroy() function.
>>>>> Here is my demo code:
>>>>> main.cpp (most simple case for a bigger project where it's necessary to
>>>>> load and unload different shared libraries at runtime without
>>>>> terminating main application)
>>>>> #include <windows.h>
>>>>> #include <iostream>
>>>>> int main()
>>>>>     HINSTANCE hinstLib;
>>>>>     BOOL fFreeResult;
>>>>>     hinstLib = LoadLibrary(TEXT("myCaLib.dll"));
>>>>>     if (hinstLib == NULL) {
>>>>>         std::cout << "myCaLib.dll not found" << std::endl;
>>>>>         return 1;
>>>>>     std::cout << "library loaded; hit ENTER to unload" << std::endl;
>>>>>     getchar();
>>>>>     fFreeResult = FreeLibrary(hinstLib);
>>>>>     std::cout << "bye" << std::endl;
>>>>>     return 0;
>>>>> _______________________________________________________________________
>>>>> myCaLib.cpp (most simple shared library with no functions except
>>>>> creating and releasing the Channel Access context)
>>>>> #include <iostream>
>>>>> #include <cadef.h>
>>>>> BOOLEAN WINAPI DllMain(HINSTANCE hDllHandle, DWORD nReason, LPVOID
>>>>> Reserved) {
>>>>>     switch (nReason)
>>>>>         case DLL_PROCESS_ATTACH: {
>>>>>             int32_t iResult =
>>>>> ca_context_create(ca_enable_preemptive_callback);
>>>>>             if (iResult != ECA_NORMAL) {
>>>>>                 std::cout << "Error: Could not create any instance of
>>>>> Channel Access." << std::endl;
>>>>>                 return 0;
>>>>>             std::cout << "New instance of Channel Access context." <<
>>>>> std::endl;
>>>>>             std::cout << ca_context_status(ca_current_context(), 1) <<
>>>>> std::endl;
>>>>>             break;
>>>>>         case DLL_PROCESS_DETACH: {
>>>>>             std::cout << "detach process ... " << std::endl;
>>>>>             ca_context_destroy();
>>>>>             break;
>>>>>     return 1;
>>>>> build at command line at Windows 7 64 bit
>>>>> %comspec% /k "C:\Program Files (x86)\Microsoft Visual
>>>>> Studio\2019\Community\VC\Auxiliary\Build\vcvars64.bat"
>>>>> set base=C:\base-7.0.x            <== directory of nightly build or
>>>>> stable EPICS BASE 7.0 (built with "EPICS_HOST_ARCH=windows-x64")
>>>>> cd C:\test_case\                       <== directory of our test sources
>>>>> main.cpp and myCaLib.cpp
>>>>> cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE
>>>>> -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -EHsc -DEPICS_BUILD_DLL
>>>>> -DEPICS_CALL_DLL -I%base%/include/compiler/msvc
>>>>> -I%base%/include/os/WIN32 -I%base%/include -c main.cpp myCaLib.cpp
>>>>> link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref
>>>>> -release -version:7.0 -MACHINE:X64 -libpath:%base%\lib\windows-x64
>>>>> -out:myCaLib.dll -implib:myCaLib.lib myCaLib.obj ca.lib Com.lib
>>>>> link -nologo -LTCG -incremental:no -opt:ref -release -version:7.0
>>>>> -MACHINE:X64 -out:test.exe main.obj
>>>>> set path=%base%\bin\windows-x64;%path%
>>>>> test.exe
>>>>> test.exe will freeze because it hangs on ca_context_destroy()
>>>>> I need any solution for this case, please.
>>>>> Best regards
>>>>> Carsten
>>>>> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
>>>>> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
>>>>> Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
>>>>> Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
>>>>> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
>>>>> Postadresse:
>>>>> Hahn-Meitner-Platz 1
>>>>> D-14109 Berlin
>>> Postadresse:
>>> D-14109 Berlin
>> Complexity comes for free, simplicity you have to work for.
> Postadresse:
> D-14109 Berlin
BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Carsten Winkler via Tech-talk
Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Michael Davidsaver via Tech-talk
Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Carsten Winkler via Tech-talk
Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Johnson, Andrew N. via Tech-talk
Prev: Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Michael Davidsaver via Tech-talk
Next: AW: pco Camera USB and IEEE interface Sintschuk, Michael via Tech-talk
Prev: RE: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Freddie Akeroyd - UKRI STFC via Tech-talk
Next: Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Michael Davidsaver via Tech-talk
