Subject: Re: PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: "Yendell, Gary (DLSLtd,RAL,LSCI)" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 21 May 2020 15:58:08 +0000
Thanks!  That is helpful.
Kevin
On 5/21/20 9:02 AM, Yendell, Gary (DLSLtd,RAL,LSCI) wrote:
> Hi Kevin,
> I have added a section to the docs to demonstrate the difference PVI
> would make in terms of ongoing development:
> https://pvi.readthedocs.io/en/latest/drivers.html#ongoing-development
> I think the key thing to note is that if you have an existing module,
> you do not need to hand construct the YAML file. You can run a one time
> script to generate it from the existing template file(s).
> Cheers,
> Gary
PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Re: PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file Peterson, Kevin M. via Tech-talk
Re: PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Prev: Re: PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: Displaying string Waveform in CaQtDM Paul Nord via Tech-talk
Next: Re: PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file Mark Rivers via Tech-talk
