Subject: RE: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug"
From: Freddie Akeroyd - UKRI STFC via Tech-talk <[email protected]>
To: Carsten Winkler <[email protected]>, "Heesterman, Peter J" <[email protected]>, "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 25 May 2020 14:30:55 +0000
Hi Carsten,
Glad to hear you now have a working solution on Windows.
When dlclose() is called on Linux it decrements an internal reference counter on the library, and when the counter reaches zero the library is unloaded. So if you were to call dlopen(“path to my library”) from within your library to create an additional reference to it, then when LabVIEW calls dlclose() the library should remain loaded as the reference count will still be above zero. There appears to be a RTLD_NODELETE flag that has been available since glibc 2.2 and can be passed to dlopen() to keep the library loaded after a dlclose(), it may be worth adding that too if the flag is available, but I would have thought a single dlopen() to increase the reference count would be enough.
The reference counting principle also applies on windows, so the GET_MODULE_HANDLE_EX_FLAG_PIN flag may not be needed as the call to GetModuleHandleEx() will have increased the internal reference count on the library by one.
If you wanted to have an (optional for the user) way to unload channel access without terminating labview then the following might work:
-          In your library call GetModuleHandleEx() in DLL_PROCESS_ATTACH to increase the reference count as currently, but without GET_MODULE_HANDLE_EX_FLAG_PIN. This additional module reference should be stored in a global variable.
-          In the disconnect.vi call a separate function in your DLL that calls ca_context_destroy() directly (as Peter describes below) but which also then calls FreeLibrary() on the previous stored GetModuleHandleEx () reference.
Freddie
Sent: 25 May 2020 09:51
To: Heesterman, Peter J <[email protected]>; Johnson, Andrew N. <[email protected]>; Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>; [email protected]
Subject: Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug"
Hi there,
up to now "caLabDisconnect.vi" is optional. The success of the CA Lab is the simple black box concept. You can use "caLabGet.vi" whenever you want without any separate "connect.vi" nor "disconnect.vi". I would like to retain this concept. Therefore, the additional function with "ca_task_exit()" is no solution in the CA Lab case.
Thanks to the hint from Michael and the friendly request from Freddi, I followed up the concept GetModuleHandleEx() with GET_MODULE_HANDLE_EX_FLAG_PIN. And this seems to be the key.
Now I can use my old code without any deadlocks. LabVIEW can open and close VIs with CA Lab repeatedly without problems. But LabVIEW must now be closed completely to get rid of CA Lab and Channel Access. I don't think that should be a problem.
Is there a similar solution (prevent unload library) for Linux?
Best regards
Carsten
Am 21.05.20 um 11:56 schrieb Heesterman, Peter J:
Hi Carsten,
See https://stackoverflow.com/questions/35828004/waitforsingleobject-for-thread-object-does-not-work-in-dll-unload
Basically calling ca_context_destroy()  from within DLLMain() is not an option, as it will cause deadlock.
It will need to be explicitly invoked - prior to DLL unload -  from within application code.
This might be from within your caLabDisconnect.vi?
If this is not an option, a more complex approach (as described in the article) involving 2 DLLs is possible.
But this more complex and I haven’t tested that, to date.
I changed your test code like below, and it exits normally.
All the best,
Peter.
#include <windows.h>
#include <iostream>
#include <epicsExit.h>
#include "myCaLib.h"
int main()
       HINSTANCE hinstLib;
       BOOL fFreeResult;
       hinstLib = LoadLibrary(TEXT("myCaLib.dll"));
       if (hinstLib == NULL) {
              std::cout << "myCaLib.dll not found" << std::endl;
              return 1;
       std::cout << "library loaded; hit ENTER to unload" << std::endl;
       getchar();
       myCaLibClosing();
       fFreeResult = FreeLibrary(hinstLib);
       std::cout << "bye" << std::endl;
       return 0;
// myCaLib.cpp : Defines the exported functions for the DLL application.
#include <iostream>
#include <cadef.h>
#define epicsExportSharedSymbols
void myCaLibClosing()
       ca_task_exit();
BOOLEAN WINAPI DllMain(HINSTANCE hDllHandle, DWORD nReason, LPVOID
       Reserved) {
       switch (nReason)
       case DLL_PROCESS_ATTACH: {
              int32_t iResult =
                     ca_context_create(ca_enable_preemptive_callback);
              if (iResult != ECA_NORMAL) {
                     std::cout << "Error: Could not create any instance of Channel Access." << std::endl;
                     return 0;
              std::cout << "New instance of Channel Access context." << std::endl;
              std::cout << ca_context_status(ca_current_context(), 1) << std::endl;
              break;
       case DLL_PROCESS_DETACH: {
              std::cout << "detach process ... " << std::endl;
              break;
       return 1;
Sent: 19 May 2020 10:40
To: Johnson, Andrew N. <[email protected]>; Carsten Winkler <[email protected]>
Hi Andrew, Carsten,
I may be able to help with this, if that would be beneficial.
I myself use caLab quite extensively.
Cheers,
Peter.
From: Tech-talk <[email protected]> On Behalf Of Johnson, Andrew N. via Tech-talk
Sent: 18 May 2020 18:57
Cc: EPICS tech-talk <[email protected]>
Hi Carsten,
I’m not aware of anything that has actually been added to libCom or libca recently to prevent a completely shutdown; are you saying that you used to be able to unload the CA library and you can’t now? I don’t believe this has ever been possible (which is probably what Michael is also going by), but I might be wrong – please let us know what version of Base you were using if and when you could do that.
If it’s your requirement that has changed we would be happy to advise someone how to work out what needs to be modified to allow the complete unloading that you’re looking for, but I can’t promise that we’ll have core developer effort available to do the actual investigation and any development needed (we all manage our own time and have our own priorities controlled by our employers, so I can’t speak for the others).
- Andrew
On May 18, 2020, at 12:21 PM, Carsten Winkler via Tech-talk <[email protected]> wrote:
thank you for your answer. This are bad news for our community. Many users are waiting for an EPICS Base upgrade for the Open Source software CaLab (interface beween LabVIEW and EPICS).
Best reganrds
Carsten
Am 18.05.2020 um 18:27 schrieb Michael Davidsaver:
libca and especially libCom can't be completely shutdown, and therefore
can't be safely unloaded.
On 5/18/20 8:34 AM, Carsten Winkler via Tech-talk wrote:
for a project I need to load and unload the Channel Access context in a
shared library. Loading is no problem but unloading. It always fails
during ca_context_destroy() function.
Here is my demo code:
main.cpp (most simple case for a bigger project where it's necessary to
load and unload different shared libraries at runtime without
terminating main application)
#include <iostream>
int main()
    HINSTANCE hinstLib;
    BOOL fFreeResult;
        return 1;
    getchar();
    return 0;
_______________________________________________________________________
myCaLib.cpp (most simple shared library with no functions except
creating and releasing the Channel Access context)
#include <iostream>
#include <cadef.h>
Reserved) {
    switch (nReason)
            int32_t iResult =
                return 0;
std::endl;
std::endl;
            break;
            ca_context_destroy();
            break;
    return 1;
build at command line at Windows 7 64 bit
%comspec% /k "C:\Program Files (x86)\Microsoft Visual
Studio\2019\Community\VC\Auxiliary\Build\vcvars64.bat"
set base=C:\base-7.0.x            <== directory of nightly build or
stable EPICS BASE 7.0 (built with "EPICS_HOST_ARCH=windows-x64")
cd C:\test_case\                       <== directory of our test sources
main.cpp and myCaLib.cpp
cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE
-D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -EHsc -DEPICS_BUILD_DLL
-DEPICS_CALL_DLL -I%base%/include/compiler/msvc
-I%base%/include/os/WIN32 -I%base%/include -c main.cpp myCaLib.cpp
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref
-release -version:7.0 -MACHINE:X64 -libpath:%base%\lib\windows-x64
-out:myCaLib.dll -implib:myCaLib.lib myCaLib.obj ca.lib Com.lib
link -nologo -LTCG -incremental:no -opt:ref -release -version:7.0
-MACHINE:X64 -out:test.exe main.obj
set path=%base%\bin\windows-x64;%path%
test.exe
test.exe will freeze because it hangs on ca_context_destroy()
I need any solution for this case, please.
Best regards
Carsten
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Postadresse:
D-14109 Berlin
Complexity comes for free, simplicity you have to work for.
Postadresse:
D-14109 Berlin
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Carsten Winkler via Tech-talk
Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Michael Davidsaver via Tech-talk
Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Carsten Winkler via Tech-talk
Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Johnson, Andrew N. via Tech-talk
Prev: Re: BASE 7.0.x@Windows_64 - Channel Access Context in shared library - "ca_context_destroy bug" Carsten Winkler via Tech-talk
Next: questions for mrfioc2 users Michael Davidsaver via Tech-talk
Next: PVI Prototype - a framework for specifying the interface to an EPICS driver in a single YAML file Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
