1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: Minor issues building base 7.0.4 on Windows
From: "Johnson, Andrew N. via Tech-talk" <tech-talk at aps.anl.gov>
To: "Rivers, Mark L." <rivers at cars.uchicago.edu>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 5 Jun 2020 21:38:02 +0000
Hi Mark,
On Jun 5, 2020, at 4:01 PM, Mark Rivers <rivers at cars.uchicago.edu> wrote:
That worked, thanks.  Now when I run make a second time I only see the following lines.  I assume this is normal?
H:\epics\base-7.0.4>make -sj
dbHeaderTest.c
dbHeaderTestxx.cpp
I can see why that’s happening, there’s nothing you can easily do to stop it apart from comment them out in the modules/database/test/std/rec/Makefile (those files get recompiled every time on Linux as well). This might get fixed at some point, depending on how busy we are.
Yes, applying that change to convertRelease.pl eliminated the errors like the following:
Can't locate EPICS/Path.pm in @INC (you may need to install the EPICS::Path module) (@INC contains: H:/epics-devel/base-7.0.4/src/tools/../../lib/perl C:/Perl64/site/lib C:/Perl64/lib .) at H:/epics-devel/base-7.0.4/src/tools/convertRelease.pl line 24.
Thanks, that fix will be in the next release.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Minor issues building base 7.0.4 on Windows Michael Davidsaver via Tech-talk
Minor issues building base 7.0.4 on Windows Mark Rivers via Tech-talk
RE: Minor issues building base 7.0.4 on Windows Mark Rivers via Tech-talk
Re: Minor issues building base 7.0.4 on Windows Mark Rivers via Tech-talk
Re: Minor issues building base 7.0.4 on Windows Johnson, Andrew N. via Tech-talk
Prev: RE: Minor issues building base 7.0.4 on Windows Mark Rivers via Tech-talk
Next: Re: Minor issues building base 7.0.4 on Windows Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
ANJ, 05 Jun 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
