1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: IOC Startup - init value used sometimes instead of put
From: "J. Lewis Muir via Tech-talk" <tech-talk at aps.anl.gov>
To: Paul Nord <Paul.Nord at valpo.edu>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Tue, 16 Jun 2020 15:17:26 -0500
On 06/16, Paul Nord via Tech-talk wrote:
> Strange problem.
> A. I create a bunch of PV's with initial values.
> B. A little later in the code another configuration file is read for values
> and put is called.
> C. IOC is started.
> D. Some of the PV's get the correct values.  Some still show init value.
> If I call the configure routine to set the PV's "some time" later, the load
> reliability.
> I can add a 30 second delay, but I've lost confidence that I can
> guarantee initialization under circumstances where processor load might
> change.  It looks like the "init" value is being set some random time after
> the PV is created.  Possibly even overwriting later calls to put.
> I'm using Python Soft IOC.
> Thoughts?
Where is iocInit called in your A-D sequence?  Are CA links involved?
Possibly related to this?
  https://epics.anl.gov/tech-talk/2012/msg02082.php
Lewis
IOC Startup - init value used sometimes instead of put Paul Nord via Tech-talk
Prev: Re: IOC Startup - init value used sometimes instead of put Mark Rivers via Tech-talk
Next: Re: IOC Startup - init value used sometimes instead of put Paul Nord via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: RE: IOC Startup - init value used sometimes instead of put Mark Rivers via Tech-talk
Next: No PV record found when build ASYN application on Windows shenzb--- via Tech-talk
ANJ, 17 Jun 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
