Subject: Multiple inputs in File Selector (Text Input widget Control System Studio)
From: Adrian Martinez via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 17 Jun 2020 13:42:38 +0200
I need to select multiple input files using the File Selector widget from CSS but I found a bug.
For example, if multiple files are selected, the returned string, by this widget, is each file path separated by '|', but the first file path always is replaced by the last file path.
Thanks, Adrián.
 This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
Prev: No PV record found when build ASYN application on Windows shenzb--- via Tech-talk
Next: Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Prev: Re: No PV record found when build ASYN application on Windows Johnson, Andrew N. via Tech-talk
Next: EPICS Records at Runtime Mostafa, Jalal (IPE) via Tech-talk
