Subject: question about monitering pv by using jcae
To: [email protected]
Date: Tue, 30 Jun 2020 09:00:48 +0800 (GMT+08:00)
Dear all:
 I use jcae to monitor 100 PVs of softIoc。 All theses pv value equals a specific pv named trigger plus a constant , and set SCAN=0.1s. To make sure all pv changes every 0.1s, I use pyepics to put a new value to the trigger pv every 0.1s . In my readout program,I monitor all 100 PVs.
Every 1000s , I calculate all 100 pv update times. Ideally , every 1000s the update times is 100*1000*10. But i only get 999932., which means there are0.0068% update data lost. Then I only montor 50 PVs, this time i get all update data . When I monitor 3000 PVs, the lost ratio is 0.095%.
  Is that means in one ioc database , if i want get all update data , I only can monitor 50 PVs? Or i don't do the test right?
  When number of pv is growing, is it normal to lost update data?
Re: question about monitering pv by using jcae Ralph Lange via Tech-talk
Prev: Re: Sub record not finding INAM and SNAM Ernesto Paiser via Tech-talk
Next: Re: question about monitering pv by using jcae Ralph Lange via Tech-talk
Prev: ci-scripts 3.1 release: support for GitHub Actions Ralph Lange via Tech-talk
