Subject: Array PV doesn't update in CSS BOY
From: Adrian Martinez via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 7 Jul 2020 12:17:55 +0200
Hi, I have an Asyn driver and one of the PV (asynInt32ArrayIn) doesn't update in CSS BOY.
If you run the opi, the PV gets values but never update them again ( unless the opi is updated) .
I attach the PV in .db file:
record(waveform, "$(user):DInILKArrayPreRdbk")
field(DTYP, "asynInt32ArrayIn")
field(INP  ,"@asyn($(PORT),$(ADDR),$(TIMEOUT))DInILKArrayPre")
field(SCAN ,"I/O Intr")
field(FTVL, "ULONG")
field(NELM, "512")
field(PINI, "YES")
field(DESC ,"Interlock status array")
This PV is used by a widget, which runs a script, being my PV an 'input PV'.
Can anyone help me with this?
Thanks, Adrián.
 This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
Re: Array PV doesn't update in CSS BOY Mark Rivers via Tech-talk
Prev: Question about running cs-studio/phoebus with Channel Archiver Elena Malanushenko via Tech-talk
Next: Bug Text Input (Selector Type: file) CSS BOY Adrian Martinez via Tech-talk
Next: Re: Array PV doesn't update in CSS BOY Mark Rivers via Tech-talk
