Subject: Get/Set Local Variable in motorAxis From sub Record
From: William Cork via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Wed, 8 Jul 2020 02:06:54 -0700
Hi All,
I'm trying to find the best solution to interlock motion from multiple other records. My current thinking is to link the VALs of these records to a sub record and have the C function modify a variable within the motor driver.
The issue I have is that I cannot find a way to link the instance of the drive I would like to have access to in the sub record process function. Is there a way to pass a reference of a controller instance to a subroutine process function?
Is there a simpler solution to this? Could the result of the sub record be linked to a field in the motor record to prevent motion?
Thank you,
Will
RE: Get/Set Local Variable in motorAxis From sub Record Mark Rivers via Tech-talk
Prev: Re: Re: Epics iocInit() fandayu--- via Tech-talk
Next: Fw: Re: Epics iocInit() fandayu--- via Tech-talk
Prev: Re: How to resolve CA beacon routing error messages when rebooting IOC is not helping Hu, Yong via Tech-talk
Next: RE: Get/Set Local Variable in motorAxis From sub Record Mark Rivers via Tech-talk
