Using caput does the same, using caput -S fails with "Error from put operation: Invalid element count requested".
----- Original Message -----
To: "Patrick Nonn" <patrick.nonn at desy.de>
Cc: "tech-talk" <tech-talk at aps.anl.gov>
Sent: Friday, 10 July, 2020 14:05:41
Subject: Re: Long String support in phoebus
What happens if you use caput?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Nonn, Patrick via Tech-talk <tech-talk at aps.anl.gov>
Sent: Friday, July 10, 2020 6:57 AM
To: tech-talk
Subject: Long String support in phoebus
Hi everyone,
I try to write an lso record with a text entry widget. The string is cut at 40 characters. Is there something to be taken into account, apart from:
preference "org.phoebus.pv.ca/max_array_bytes" set to a high enough number
field SIZV set to a high enough number
Greetings
Patrick
- Re: Long String support in phoebus Ralph Lange via Tech-talk
- Re: Long String support in phoebus Mark Rivers via Tech-talk
- Long String support in phoebus Nonn, Patrick via Tech-talk
<2020>
<2020>
