1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: SteamDevice 2.8.x build on Windows issue
To: tech-talk <tech-talk at aps.anl.gov>
Date: Sun, 19 Jul 2020 21:19:29 +0800 (GMT+08:00)
Hi all,
  I find that the SteamDevice(from 2.8 to 2.8.14) can not be built on Win7 x64. The error info is :../ChecksumConverter.cc:777:51: error: expected ')' before 'SCNx8'. However the version of 2.7.14 can be built successfully. I've checked the file ChecksumConverter.cc, there is some difference between them like following:
2.8.x:   if (sscanf(input(cursor+2*i), "%2" SCNx8, &inchar) != 1)
2.7.14:  if (sscanf(input(cursor+2*i), "%2X", &inchar) != 1)
The software environment I'm using:
OS:Win7 x64
base:3.15.8
asyn:4-38
MSVC:2019 community
GNU make:4.2.1
Strawberry:5.30.1
PS:SteamDevice 2.8.14 is dependency with git, the other versions are not
Cheers,
Xuan
RE: SteamDevice 2.8.x build on Windows issue Mark Rivers via Tech-talk
Prev: Re: two IOC run as a time Mark Rivers via Tech-talk
Next: stream is installing files in the wrong place Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Prev: Re: two IOC run as a time Hitesh Dhola via Tech-talk
Next: RE: SteamDevice 2.8.x build on Windows issue Mark Rivers via Tech-talk
ANJ, 20 Jul 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
