Hi
Is there any way to access V7 records using caget? I am aware that “QSRV” does the pvget(pvaccess) for V3 records but other way around is not possible i.e caget(channel access) for V7 records.
Many Thanks
Sandeep Malu
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
- Re: caget for base7 records Johnson, Andrew N. via Tech-talk
RE: SteamDevice 2.8.x build on Windows issue Freddie Akeroyd - UKRI STFC via Tech-talk
<2020>
2025
stream is installing files in the wrong place Mark Rivers via Tech-talk
<2020>
2025
ANJ, 20 Jul 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
