Subject: Re: pvData Introspection: Change Structure at run time
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Madden, Timothy J." <[email protected]>
Date: Mon, 27 Jul 2020 17:29:00 +0000
There are 'union' types as used for the value in the area detector data if you want to change some part of the structure at runtime, but generally I don't think you can change the structure at runtime.
The protocol exchanges the structure description at connection time, specifically at the start of a 'get' or 'monitor'. Later just the raw bits are exchanged with some reference to what part of the structure changed.
If you want to modify the structure, you'll have to basically dispose/close the channel and re-create it. Clients should then re-search and on re-connection they'll learn about the new structure.
-Kay
From: Tech-talk <[email protected]> on behalf of Madden, Timothy J. via Tech-talk <[email protected]>
Sent: Monday, July 27, 2020 1:23 PM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] pvData Introspection: Change Structure at run time
Folks
Most of the interfaces for Structure require a StructureConstPtr data type.
This is a pointer to an immutable structure.
Suppose I wish the structure to change at run time. What do we do?
Tim Madden
APS
pvData Introspection: Change Structure at run time Madden, Timothy J. via Tech-talk
Prev: pvData Introspection: Change Structure at run time Madden, Timothy J. via Tech-talk
Next: EDM fonts on Raspian ... Ernesto Paiser via Tech-talk
Next: Re: pvData Introspection: Change Structure at run time Marty Kraimer via Tech-talk
